What kind of MPG do you get?
I have an 82 automatic I just got 200miles ago and MPG seems OK but I have not checked it being most driving was city. 1982 Car and driver says 12mpg but they also say my 04 GTO gets 18 when I get about 25+ on highway. I know it will differ but what are people getting with each model, stick vs auto? Hwy and mixed? Also what grade fuel do you run? I am running 93 octane but manual states 87...is that right?
78-82 mpg?
83-86
86.5-89
etc.
78-82 mpg?
83-86
86.5-89
etc.
Range Master
Pepsie Lite
Pepsie Lite
As long as I keep my foot out of it I can get around 18 MPG on average. Putting my foot into it, with the blower on full tilt, I can get into the low single digits..... (even though the digital read out is lying to me...... I am running 30# injectors) I burn 93 or better..........moonshine if I can get it......
Run ONLY as high as the car is designed for. In your case running 93 is a complete waste of money. Higher Octane rated fuel is NOT better,more powerful ,cleaner it simply explodes slower....
Administrator - "Tyson"
At 6psi my 81 averages about 11-14mpg on my daily commute - I run 93 octane. Without the blower I never ran anything higher than 87 octane.
I filled up two days ago and got 15.7 MPG on that tank. That is 50 / 50 city / highway and every time that I drive, I test to make sure that I am seeing full boost under WOT.
I get around 19-20 if keeping it below 80ish. Car is a 1987 S4 Auto with approx 88k. Mods include advanced cams (slightly), no air pump, no cats, RMB. I also have slightly increased stall speed. Will power brake to approx. 2200 rpm. This affected gas mileage only slightly. Converter tightens up quickly once under way (at hwy speed).
4 to 5 mpg at Road America in Ronn's GT racecar.
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Andrew Olson
Yeah... I do that too!
