Nice wheels, okay offset
I have mentioned these before. They worked GREAT on my 86. VERY light, and good price.
Now they have an even better rear size,
http://cgi.ebay.com/ebaymotors/ws/eB...DME:B:AAQ:US:1
Originally Posted by morganabowen
You bought a set of these Man, you can't beat the price
Originally Posted by Bill Ball
Which offset would be better for the rear 10" for an S4 w/o spacers? 48 or 60?
Well, a 10" Twin Turbo wheel with 275s and a 65mm offset is a bit IN for my tastes. So The lower offset of 48 with that wide of a wheel, will, I think, limit your tire choices.
So I would think this 60mm offset would be perfect for a stock car with very little fender rolling. The 50mm offset with the 8inch wheel on my 86 front took a 245 tire, and its tight, but great turn in - best of any 928 I have driven, and when I took the rack apart it has a 1/8" play in each tie rod, and the bushings had returned to their original state: black goop.
Supercharged
On a 10" rim, I think the 60MM offset will be fine. Worst case you need a little spacer.
These wheels are tempting. I've been thinking about getting something wider than a 9", but I think I should bite the bullet and go to the 11" rim, albeit harder to find. But I'm goign to keep these in mind.
Bredan -
DO you have a pic of them on your car?
Bredan -
Originally Posted by Andrew Olson
Brendan -
This is funny:
http://cgi.ebay.com/ebaymotors/20-9-...QQcmdZViewItem
9" x20. 60mm offset. This could be all around.
Of course we are down to the 550s for knock off turbo twists.
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
I wonder how heavy though?
