Fire Extinguisher Mount Pics and Comments
Originally Posted by morganabowen
BTW...How much do those BK systems cost
Archive Gatekeeper
Well, that BK mount is certainly pimp, but for ~$200, I'd rather have entire trio of the Halotron FE, its red mount, and the SE bracket. Of course, I haven't put the seat back in the car, nor given the wife a chance to tear her skirt on the exposed FE handle, so we'll see how that goes.......
EDIT:
Larry, if you buy the SE bracket and parts and drive down here, I'll mount it up for you. I could probably re-do the whole thing in 30 minutes.
Also, it turns out (maybe this is common knowledge, but it wasn't for me..) there are 2 sets of set mounting holes- mine are in the front position, but I'm 6'4"- when I pull the driver's seat to Leatherique it, I'll be bying myself an extra 25 mm of legroom.
EDIT:
Rob, the most important thing is that you have a FE in easy reach and that it's NOT a dry chem. If your wife snags something on it, then the fancier mounts are a no-brainer. If you you went with one of the fancier mounts out of the gate, there would be questions about "why did you spend so much money on a FE mount". In my case, I had to put up with a lot of suggestions about where to put the FE(not all of them anatomically possible) until I put my foot down and said "that's where it's going, PERIOD, we can put a towel over it till I find a better solution that doesn't dig into your legs".
EDIT:
EDIT:
Anybody use the Dupont clean agents instead of Halon or Halotron? Apparently it is far less harmless and non-corrosive. It is also not restricted (Halon) or scheduled to be restricted (Halotron I).
Sharkaholic
I still have dry chem ones in my cars, yeah they leave a mess but, big but, at least I'll just be cleaning up a mess not shopping for a replacement again...
When the funds allow I'll add the Halotron and the engine bay supression sytem similar to what Alan has.
till then I carry not one but two, a 2.5 pounder and a 5 pounder.
Shane, I know this issue is real close to home for you. I'd be carrying whatever fire ext. I could get my hands on if I were you as well. Anything is better than having nothing, you'll get no argument from me on that!
I mod the mount so it sits lower away from passenger's legs. https://rennlist.com/forums/members/...9-cimg1275.jpg
