Best method for removing carbon from valves, cylinder heads and pistons? (lapping)
Hello all
I have been looking for a small nylon cleaning brush to go onto a diegrinder to use to remove carbon from the combustion chambers, removed valves, and piston tops. Anyone know where i can get a disc or some type of cleaning material thats safe to use on the aluminum heads and pistons as well as the valves themselves.
I would assume an abrasives supplier would have what i am looking for, I will try couple places local to me tomorrow, but I thought I would post and see if anyone else knows of a great way to remove the old carbon off those various parts.
GM has a product called top engine cleaner in a foam spray or liquid. It is intended for carbon removal while engine is running. I have found that it also helps to break down carbon and varnish on disassembled parts. 3M makes roloc cleaning discs in various grades and sizes.
Yeah i am familiar with that type of stuff, but i am looking for something thats used to remove carbon from engine parts, as in not running but individual pieces.
I used a dremel tool... there is a bit that is sort-of like a tough sponge. It effectively removed the carbon from all the little nooks without scratching the aluminum. It took about 8 or 10 bits to do the whole job... but they're only a buck or two.
The product is called "Roloc", it is velcro pad on a shaft that fits a 1/4" drill, that takes scotchbrite pads. The less agressive pads work well for removing carbon, and not harming the aluminum surface. Available from hardware or body shop supply stores.
http://www.autotoolmart.com/cgi-bin/...ml?p_catid=148
3M makes a special brush designed to be mounted to a die grinder. It should remove carbon, but not alter the surface of metal components.
3M Roloc Bristle Discs:
http://www.tool-co.de/news/bristle/Bristle3.jpg
Mike those are what i was looking for, Now where the hell do i find those locally, they dont seem to be the typical thing you find in local hardware shop. I have seen these in action but never knew what they were marketed as or who made them. Thanks
Off to the local abrasives store tomorrow
still if anyone has other methods to suggest by all means please post them
Under the Lift
I dumped some heavily carboned motorcycle pistons and valves in some Berrymans parts cleaner - sold in gallon cans - closed the can and let them sit for a month. That did it - a few days won't do it. Note this solvent leaves a tacky residue, but I discovered it washes off in plain water.
Rest in Peace
Be carefull they will remove metal, never use them on a sealing surface.
Originally Posted by Mike Simard
For commonly available things, there's oven cleaner.
Chronic Tool Dropper
Most oven cleaners are quite caustic, and will do a number on the aluminum. Ryan-- the 3M pads are usually available at body shop supply places. There are more than a few in our neighborhood.
The 'parts dip' solution is often a little acidic. Aluminum bits left in there for an extended period will come up gray and oxidized.
If the parts are out of the car/engine:
Valves clean up nicely with a medium steel wire wheel/brush on the grinder. The steel in the valves is as tough as the wire wheel, so no worries with damage.
Piston tops are pretty durable. You can take the bulk of the carbon off with the same wire wheel, but stay away from the edges and the ring lands. For those areas, a solvent soak for a week will help without risking the metal at all. Then a hand cleaning with a 3M scotchbrite pad will remove the last chunks. Use a proper ring groove cleaner to keep the edges of the lands from being damaged when you clean them. It just takes a little distortion or scratching with a scraper, screwdriver, razor knife, whatever, to ruin a piston. Work sitting down at the bench, over a plastic dishpan with no other parts in it. If you drop a piston on the floor or on other parts, it will likely be junk instantly.
