928 Forum 1978-1995
Sponsored by: 928 Specialists
Auto transmission flush - mechanic says don't do it
Old 03-20-2015, 07:17 PM
  #46
sstrickstein
sstrickstein's Avatar
Originally Posted by 928saregreat
If no previous maintenance record on the automatic is known and the fluid is burnt smelling and discolored I would never recommend using a T-Tech "flush" machine on the transmission. Since these cars we're so fond of were built before this technology existed (with the exception of the GTS perhaps) just do the recommended service, drop the pan, clean it, change the gasket/filter, replace the fluid in the pan ONLY. I've seen many old transmissions "shocked" into slippage by the cleaning power of 100% fresh transmission fluid. This is no myth. I see it everyday! If you don't know the history, DON'T FLUSH IT. Just by doing the recommended maintenance you're gonna get a pretty good idea of the condition by the amount of metal hanging off the magnets in the pan.
Mark
Agreed. Nuf said.
Old 03-21-2015, 12:54 AM
  #47
dr bob
Chronic Tool Dropper
dr bob's Avatar
Originally Posted by Randy V
Here's that engine Dr. Bob speaks of - I can see why a transmission in a similar state would not benefit from a fluid change.
See where the varnish protected the back of the cam lobes? No way would I want to lose that!
Old 03-21-2015, 01:43 AM
  #48
The Forgotten On
The Forgotten On's Avatar
Must be a BMW owner with that kind of sludge
Quick Reply: Auto transmission flush - mechanic says don't do it
