928 Forum 1978-1995
Sponsored by: 928 Specialists
What part numbers do I need to swap to big reds?
Old 05-26-2006, 08:30 PM
justin
justin's Avatar
Default What part numbers do I need to swap to big reds?
I need Porsche parts numbers for the items I need to convert my 80 model over to big reds. Front only for now. I thought it was 993 front rotors? I dont want to swap my spindles.
TIA
Old 05-26-2006, 08:31 PM
Mark
Mark's Avatar
928 Specialists (928gt.com) has kits on their website.
Old 05-26-2006, 08:40 PM
justin
justin's Avatar
I know I want the Porsche part numbers. I am going to try to piece a kit together.
TIA
Old 05-26-2006, 09:18 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
Hi from the PET--- L caliper Twin Turbo 993 351 425 10 , R caliper Twin Turbo 993 351 426 10,
L rotor TT 993 351 045 10 , R rotor TT 993 351 046 10, front pads Turbo 993 351 949 00, these parts bolt on to a S4. I am not sure if these part numbers equate to red calipers as there are a few different choices Black, Silver, Red, and possibly Yellow
Old 05-26-2006, 09:43 PM
ROG100
Basic Sponsor
ROG100's Avatar
Justin,
Are you going with "big reds" or S4 calipers. I have S4 calipers painted and ready to go.
Roger
Old 05-26-2006, 10:37 PM
Mark
Mark's Avatar
TIA
My bad, justin. They list most of the parts numbers you are looking for (check the 'drop down boxes' towards the bottom of the page.
Old 05-27-2006, 01:18 PM
justin
justin's Avatar
Mark, thats ok,mrmerlin, will those part numbers work on an old bugger?
Old 05-27-2006, 01:43 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Have you considered swapping to only an S4 setup? The difference between the S and S4 brakes is huge. It could be a real good bargain to swap to the S4 setup.
Old 05-27-2006, 02:37 PM
justin
justin's Avatar
I have been thinking about that.
Old 05-27-2006, 06:08 PM
Jim M.
Jim M.'s Avatar
Justin, If you go to S4 front brakes you don't have to upgrade to 17" wheels. If you go with "Big Reds" you need 17" wheels and the spare will no longer fit on the front. The Big caliper P/N's are: GTS Big Blacks 928-351-423-03, LH caliper, 928-351-424-03, RH caliper. 993 TT Big Reds 993-351-425-10, LH caliper, 993-351-426-10, RH caliper. The rotors are 928-351-045-01, LH rotor, solid, 965.351.045.00 rotor, ventilated, LH (cast holes) 322mm, 928-351-046-01, RH rotor, solid, 965.351.046.00 rotor, ventilated, RH (cast holes) 322mm. The GTS and 993TT big reds are the same except location of bleed and crossover tubes; the 911 has the caliper in front of the axle. Both use 44/36mm pistons. The C2 turbo little reds also bolt on, but the piston sizes are larger, which gives more braking force in the rear. Use the GTS or the C2 turbo rotors. You also need 1 pair brake rotor backing plates P/N 928 351 083 04 & 928 351 084 04. Cross-drilled rotors 322mm front 302mm rear. Devek’s Big Red rear caliper is 993TT rear caliper modified to fit the S4. The rear calipers (30mm & 28mm pistons) on the GTS are the same as the 944 turbo’s, 944 S2, 968, 928S4, 928GT, RS America and the later 911 C2/4. All the front-engine cars also use the same size MC with these calipers. The same rear brake package as on the Devek White car, the rear pad is the same size as the front S4 pad and the rotor is 302 x 28 mm (stock rotor, is 299 x 24 mm).
All of this bolts right up to an S4, 87 thru 91. I don't know what you need to do for an OB!
Jim Mayzurk
93 GTS 5-spd
Old 05-27-2006, 06:41 PM
Stan.Shaw@Excell.Net
Stan.Shaw@Excell.Net's Avatar
you either need to swap to S4 spindles or go with the adapter.
Old 07-25-2009, 05:15 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
Originally Posted by Jack Riffle
Justin, make the change to the s-4 brakes. Makes a HUGE difference. You will need the S-4 calipers and brake pads, 993 rotors, and the adapter that 929 SP sells. Oh, and you will also need S-4 brake lines to connect them up to your brake system. This is the setup I have on my 81, just make sure you keep distance between you and the guy following you, because I guarentee he won't be able to stop as fast as you can.
This is not true. If you use S4 brakes you cannot use the 993 rotors. You will need to use S4 rotors. If you use GTS brakes you can then use the 993 rotors. No matter which you choose, if your using OB rotors you will need the adapters.
Old 12-06-2011, 11:19 AM
heinrich
928 Collector
heinrich's Avatar
Old but good thread. So I have a set of Big Blacks (from a 911) and rotors (965.351.045.00 and 965.351.046.00) from a 94 tt. I assume these would all be direct bolt-ons for S4 -> GTS? (brake lines need to be moved to the opposite side)
Old 12-06-2011, 11:54 AM
Ed Scherer
Ed Scherer's Avatar
IIRC, you also should also switch to 10 mm longer bolts (the 80 mm long 900.067.268.02 from the GTS vs. the 70 mm long 900.067.154.02 for the original S4 calipers). That's assuming that the "Big Blacks" you're talking about are the 993TT calipers (993.351.425.10/993.351.426.10).
jthwan22 posted a nice parts summary you might want to review.
SeanR
SeanR's Avatar
Justinwho?
Quick Reply: What part numbers do I need to swap to big reds?
