Transaxle leak?- 90 GT
Another thread resurrection!
Wish I had read this thread earlier and particularly the part about using only factory gasket for top plate.
I had a pretty annoying oil leak at the tranny as well.
PO mentioned that he had the tranny rebuilt and that folks at the shop probably forgot to place a gasket at top plate.
Well, I dropped rear suspension and transaxle recently and used silicone make-a-gasket () to re-seal the top plate. Yep, it's an easy guess - it's leaking again!
you need the factory gasket because it has a piece that blocks the breather. The breather is the cause of all the leaks. With it slightly blocked by a 1" wide strip of gasket material this helps to prevent so much oil migrating out of the breather and onto the exterior of the case
Too bad I didn't get to know about it before putting everything back together.
