**SOLD**One set: BLUE OEM Beru solid-core wires with spark-plug terminals! $129
Sorry, sold in 30m...that's fast!
I have one set available: used but excellent condition & tested stock Beru spark plug terminals with new 7mm OEM Beru solid core wire & Beru M3 terminals.
This was the last of my "voodoo spool" of blue soid core wire: Voodoo because I could barely make the sets as the stranded wire was MUCH thicker than the normal wire, making it a bit more of a challenge to make a full set, but the benefit is an easier path of travel as the stranded wire cumulation is probably .04 thick or so, close to double of what I've seen in 20-year old solid-core wire.
Only set, with spark-plug terminals (all tested within factory specifications), $129 for the one set, $11 shipping (US ground).
PM me if you want them, first PM gets them.
Mark
Mark
beru plug wires
Do you happen to know if Beru wires are "solid Core"? I just installed an MSD 6al ignition system on my 79 911SC and they say not to use solid core plug wires. I have the Beru Stainless steel sheathed wires on currently and I am getting a lot of breaking up/ or missing in the 3000 rpm range.
