Oil pressure maxxed out.
My oil pressure gauge is reading almost 4/4 then when I blip the throttle it maxx's out. Im thinking some sort of electrical gremlin. Any experience here?
86.5 manual
86.5 manual
Captain Obvious
Super User
Super User
The 928 gauges are extremy inaccurate. As song as they give you a reading, don't worry about what they show....as long as it'n not 0 and the ! is flashing!
If this problem just started to occur, I suspect the oil pressure sending unit to be at fault.
And yes, the oil pressure gage should read 5 when the engien is revving up.
Mike
Since there is a difference between the idle and higher rpms reading, then it is probably fine....typically when they fail they default to 5 bar all the time and don't move. Does the warning flash when it goes above 5 bar? Also what weight/type of oil?
