Where is outer temp sensor?
Where is the outside temp sensor located giving signal to the outside temp meter on the digital dash?
Is it the same sensor used for the climate control in the left front wheel well?
Thanks/Peter
Thanks/Peter
Thanks that was quick,
have been searching the WSM and can not find it.
Is it the same location 89-95?
Do you know the colour on the cables, need to check for continuity.
Cheers/Peter
Cheers/Peter
Supercharged
On the 90-91 the 2 wires for the temp sensor are Blue-Green and Brown-Green. Hope this helps.
Edit: That's at the temp sensor... don't know if it stays the same color up to the pod.
Minus 40 reading equals cut wire - most common site is in trunking as leaves door and enters car. Fatigue often breaks the wires and the temp sensor seems to be the one that goes first. No idea why, but that's what happened to mine.
Good luck
Mark
Good luck
Mark
