Water Pump Gasket - Dry or use a Sealer?
Dry dry and dry. Have done several WP's to date and never used sealant...never had a leak. Using sealant just makes a dumb mess for the next time you have to do the job. The only time you should use sealant is if some clown before you marred up the mating surfaces leaving nicks and gouges from using the WRONG TOOL...OR. if you just plain do not know how to torque bolts with the proper inch/lbs wrench in a star pattern.
