928 Forum 1978-1995
Sponsored by: 928 Specialists
Delco Alternator Conversion
Old 12-30-2005, 07:26 PM
toofast928
toofast928's Avatar
Default Delco Alternator Conversion
Fed up with the Bosch 55 amp rebuild?! Do this:
Delco CS 130 Alternator. Cooling fan internal as well as external. 105 amps. 14.5 V at idle. I picked it up at Auto Zone for $70.00 Lifetime warranty. Tell the counter person it's for a 1988 Camaro, 2.8L. You also need a $13.00 delco pigtail connector from Painless Wiring). One wire to splice into.
Old 12-30-2005, 07:57 PM
BrianG
BrianG's Avatar
So, this works with the original alternator's exciter resistor in the pod, and keeps the charging system's warning indications happy?
Old 12-30-2005, 08:00 PM
heinrich
928 Collector
heinrich's Avatar
APPLAUSE!!!!!!!!!!!!!! Dude I and everyone here owes you a ... THIS is what will keep our cars on the roads ..... cheap Chebby parts.
Old 12-30-2005, 08:03 PM
Weissach
Weissach's Avatar
Did it bolt in?? Or did you have to do mods?? This is very cool. I think AC delco also has 160 amp alternators
Old 12-30-2005, 08:04 PM
Weissach
Weissach's Avatar
Factory pulley?? Same belt size??
Old 12-30-2005, 08:09 PM
BrianG
BrianG's Avatar
Details, man...... the world needs DETAILS!!
Old 12-30-2005, 09:42 PM
toofast928
toofast928's Avatar
Brian G: So, this works with the original alternator's exciter resistor in the pod, and keeps the charging system's warning indications happy? Yes, no additional resistor is needed, thou the Volt gauge is still 1 volt off.
The GM pulley was ribbed, I changed over to V style. (Motorsports crank pulley is V style).
I combed the "LESTER" book for hours. Their's no direct fit alternator to cross over to. The camaro style is as close as you can get. A 5 mm spacer is all that is needed on the top bolt. Pulley alignment is perfect.
The CS 130 is a 105 amp alternator. Aftermarket has a kit to change the stator and end cover. This bumps the amps to 140. I don't think the extended end cover would clear the oil filter. The other GM alternator is the CS 144 140 amps. Is bigger in diameter again I think it would have clearence problems.
At idle speed, all accesories on (including two electric fans and 300 watt amp) the system voltage is 12.5 at 60 amps. Off idle volts go to 14.3 and 75 amps.
Without the aux fan on, voltage at idle is 14.0.
Old 12-30-2005, 10:06 PM
BrianG
BrianG's Avatar
NICE!!
Could you do up a little wiring diagram for those of us electron-challenged types?
Even a little text description of which wire goes where??
Old 12-30-2005, 10:20 PM
toofast928
toofast928's Avatar
Porsche OEM wiring to the back of the Bosch or Paris Rome alternator is one eye lug consisting of two red wires >> Battery charge.
The other connection is voltage sense/exciter. Green wire I think.
The Delco connections are:
Large battery wire to Batt terminal.
Red wire of Painless wire adapter to batt terminal.
White wire of Painless adapter to be spliced into Porsche harness, Green wire.
Painless Wire Adapter P/N 30707
Old 12-31-2005, 08:31 AM
Rod Underwood
Rod Underwood's Avatar
I notice that there is a difference between the 78-84 and the 85-94 alternators, but don't know what the difference is - wiring, physical configuration, attachment?. Does anyone know if this same conversion will work on the later version?
Rod
Old 12-31-2005, 01:31 PM
BrianG
BrianG's Avatar
From having ordered a replacement rear cover for my '86 car, and having gotten one that didn't fit, I'd say that there is a case configuration difference. There wasn't a whole lot of actual size difference in terms of the face dimensions, though...
Old 12-31-2005, 03:14 PM
PorKen
Inventor
PorKen's Avatar
Get 'er done! Nice work!
Painless Wiring #30707
GM Alternator Pigtail, CS style
Old 12-31-2005, 06:03 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Or you can go to the junk yard and snip one off. I'm sure there are plently on 2.8L GM engienes out there.
Old 01-01-2006, 03:20 PM
sparks
sparks's Avatar
Great swap toofast!! I spent $267 for a bosch unit, the delco peice is much better. One question not answered is cooling hose needed? My last alt. failed due to exhaust heat.
Old 01-01-2006, 03:45 PM
toofast928
toofast928's Avatar
Yes, cooling hose is installed. The internal cooling fan draws air in from the rear. Better cooling of the bridge and stator. But cooler air is still needed.
Quick Reply: Delco Alternator Conversion
