TB light came on
Right now i am not sure.Most likely it is a faulty sensor light but tha can change as soon as i take the tensioner out and look at it closely but like i said before i did use the kemph tool to measure the the tension and it was within specs
Rennlist Site Sponsor
Most common causes of false belt tension warnings seem to be:
- Bad connection at the round connector on the timing belt cover.
- Bad connection at the flat connector just inside the timing belt cover.
- Broken metal strip down the tensioner arm.
And, yes, the false tension warnings can be frustratingly intermittent.
