The Twin Screw Thread
#2941
I like it right there, didn't want to relocate 14 pin and large hole, not a fan of hidden filters that are hard to get to either.
With that said I was speaking w/ Darin N. a week ago (we have the same setup) and he's offered any advice / info he can give. He did make an access plate to get to his in fender Air filter so he doesn't need to remover the entire fender liner.
I'm thinking I just need to shield it a bit more (plastic box?), I have an Air temp sensor that will be installed soon to actually see what I'm drawing in and how much the temp drops when moving.
Thanks for the input Imo
Dave
Dave
#2942
Dave
Dave
#2943
Looking great Dave!!! I am so jealous. I'm so close to being ready to drop the engine in, I can taste it. :-) Hopefully it'll start and run ok, then it'll be time to Shark Tune. Numerous changes compared to what it's last configuration was so I'm sure what tune he had is no longer valid.
Just keep at it even an hr or two each night keeps a big project like these moving forward
We all need to start seeing some pic's too
Dave
#2944
I like the filter setup, just need a nice shroud to go around it. Should be easy enough to make something. slick for that location.
I can whip something up if you want to have one printed. It may be a bit large for my printer, but it could be sent out easily.
#2946
I can follow up w/ you Hans with the dimensions once I make one out of cardboard
Thank you,
Dave
SpeedToys, God speed your recovery!
#2947
Glad to see progress.
#2948
Hopefully Monday you'll start seeing pics of some progress.
Speedtoys, I hope you make a fantastic recovery, and boost the heck outa that thing!
#2949
Two quick questions for the group.
1. Can I run two new wires to the LH and EZF for the TSP (idle and WOT) ?
I'd supply engine Ground to the TSP from under the hood.
Note: the EZF only would need the Idle wire as the WOT is discoed inside the connector per 2 BAR MAP install.
2. Any good reason to keep the Diag Plug in the front of the Water bridge?
I'd never would use it with the Shark Tuner for doing O2 adjustment,
it would clean up the install as a not needed unused fixture/wiring.
Thoughts?
Dave
Thoughts?
Dave
#2950
Supercharged
As Dave mentioned, I got to take my GT out for a quick romp! HOLY FVCK that car is fast! Had the cops come by about 20 min later asking about it... I guess I pissed a couple people off. Woops!
Dave,
1. Yes. You can do this. I would run it temporarily first to make sure this fixes the issue before going through all the work of running them through the firewall, etc.
2. Not sure why you would need it...
Thoughts?
Dave
Thoughts?
Dave
#2951
Full size functional prototype of the throttle inlet linkage.
It will get bolted to the supercharger and triple checking firewall clearance tomorrow before placing purchase orders.
There are a lot of custom parts in this assembly.
The full 3D viewable assembly is here:
http://cloudviewer.spaceclaim.com/60...c07ac5f6e.html
#2953
Archive Gatekeeper
Beautiful work, Hans!
#2954
#2955
Those parts look great Han's, nice work
I wanted to give a progress update, I was able to plumb and get my Inter-cooler connected up over the past weekend including a switch to run the pump.
However once the engine got up to temp, I started to see water out the exhaust (two small 4" puddles.
I then drained the distilled water out of the reservoir tank and used my mitivac to push it out the Intercooler from the top to the rear inlet.
All is as it was before, two steps forward one back
Other than getting the Shark Tuner MK1 all set up for tuning, I'm shelving this project, will pull the engine this winter go through it and start fresh in the spring.
Current state is drive-able, but only local and cool days.
