Parts list for repaint anyone?
Cottage Industry Sponsor
Has anyone put together a complete parts list for exterior repaints? A list of all the items needed when removing and replacing glass, trim, lights, spoilers, etc.
Do any of the 928 parts vendors offer a package of all these pieces?
I suspect it will contain the following; feel free to add:
- Porsche Hood Crest
- Bumper beading front and rear
- Windshield washer nozzles
- Headlight washer nozzles
- Door window trim corners (are the other pieces required also?)
- Door window seals
- Door seals
- Rear quarter window seals, and possibly trim
- What's needed for the hatch window?
- Hatch seal
- What's needed for all the locks?
- Teflon stickers for hatch
- On s4 and later models - Teflon strips between spoiler and hatch
- ... what else?
- Door window seals
- Door seals
- Hatch seal
- ... what else?
Side molding clips, side marker light seals ,window trim corner pieces are required(they break on removal) you can reuse the rest of the window trim. Window outer and upper seals are required inner ones are not , quarter glass seal and trim (plastic) are required (quarter glass corner pieces can be reused if you are careful removing them they are metal). Door and hatch seals can be reused if in good shape. Door threshold clips and all front spoiler fasteners are a good idea. Side mirror seals, door lock seals, rear hatch lock seal and rear wiper pivot seals X2. Hatch window trim can be removed carefully and should not require replacing the same goes for the front window trim ,the hatch window itself is glued onto the hatch . The rest of what you mentioned Nicole is accurate
Regards Dan 1990 928Gt
p.s. if you plan to replace all window,door,quarter glass and rear hatch seals plan on $1600.00USD (just for the seals no joke!)
Ok my little minions,
Since I am doing a repaint and my car should be back this week, i am the most qualified banzaiier over here to give you the lowdown.... so if you're ready, here it is:
Exterior Rennovation - The Khaled way:
- Glass Off
- All Trim Off the Car (side moldings, glass edging, spoilers, bumpers, lights, etc etc etc... get the car back into a shell
Parts to be replaced
Part Number Qty Description
928 537 531 03 2 Door Lock Cynlinder Gasket
928 628 716 02 1 Front Wiper Gromet (Right Side)
928 628 717 01 1 Front Wiper Gromet (Left Side)
928 628 623 01 2 Front Wiper Arm Caps
928 628 621 00 1 Rear Wiper Arm Cap
928 628 077 00 1 Hood Washer Nozzle (Left)
944 628 077 00 1 Hood Washer Nozzle (Right)
928 528 071 02 2 Front Bumper Washer Nozzles
928 512 223 02 1 Rear Spoiler Base Foil (Left)
928 512 224 02 1 Rear Spoiler Base Foil (Right)
928 512 277 00 2 Rear Spoiler Base Gasket
928 559 281 02 10 Side Trim Clips
914 504 319 00 2 Headlight Rest Gromet
928 201 333 02 1 Fuel Filler Sleeve
928 505 051 01 1 Front Bumper Beading (Left)
928 505 143 03 1 Front Bumper Beading (Right)
928 505 145 03 1 Rear Bumper Beading
928 505 191 00 1 Front Bumper Plug
928 505 191 00 1 Rear Bumper Plug
928 537 345 05 1 Left Door Seal
928 537 346 05 1 Right Door Seal
928 512 129 04 1 Hatch Seal
928 537 341 02 1 Left Window Vibration Buffer
928 537 342 02 1 Right Window Vibration Buffer
928 537 321 03 1 Left Window Slot Seal
928 537 322 03 1 Right Window Slot Seal
928 559 119 04 1 Left Roof Edge Trim
928 559 120 04 1 Right Roof Edge Trim
928 731 247 03 1 Left Side Mirror Base Gasket
928 731 249 04 1 Right Side Mirror Base Gasket
901 559 210 20 1 Metal Hood Crest
7L5 853 611 B 1 Hood Crest Gasket
999 591 423 03 2 Hood Crest Nuts
928 512 169 03 1 Rear Hatch Lock Cylinder Gromet
928 505 335 07 1 Decal "928S4"
928 559 289 05 1 Door Sill Trim (Left)
928 559 290 05 1 Door Sill Trim (Right)
928 631 453 00 2 Front Market Light Seal
928 504 326 02 1 Gas Door Plastic Stop
803 971 979 2 7-pin Plug Sockets
928 537 301 05 1 Left Door Trim Molding
928 537 302 05 1 Right Door Trim Molding
928 631 965 00 2 Fog Lens Trim
928 504 335 02 1 Gas Door Gasket
928 564 259 02 1 Sunroof Front Gasket
928 564 261 02 1 Sunroof Rear Gasket
Since I am replacing the glass, the front headlights and fog light lenses are in a good list for renewing... so i suggest renewing due to glass chipping (20 years of service)
2 Headlights
2 Fog Lenses
That should be it for the exterior rennovation, unless you are missing lower spoilers so i would also suggest placing a new front, middle and back lower spoilers.
As far as the window and glass trim as well as wipers, they can be mostly reused and repainted (save around $1800 on those).
I would also suggest refinishing your wheels while the car is in the shop.
Sincerely,
Khaled Badr
1987 Porsche 928S4 Automatic with 177k on it and going
- Glass Off
2 Headlights
2 Fog Lenses
Sincerely,
Khaled Badr
Agreed Brain, I have all the numbers in a folder and am not sure I want to go back and scrutinize the cost, door sill trim is a good one, those are broken as soon as you remove them and $40+ each.
Chris
Chris
Khaled:
Thank you very much for this comprehensive list! I will keep this for when the day comes.
Now the only thing that would be interesting are the prices for these parts...
Questions:
1. How were the door sills handled - were the doors taken off and the sills repainted, or was the new paint blended in in the crease?
2. If the door sills had been painted completely, did you have to replace the DOT and paint color stickers? Are these available in the original look?
Thanks!
Questions:
Thanks!
928 Collector
Nicole suffice it to say that if you repaint your car, there is a 99% chance that it won't be as nice as it is today. Your car is flawless. Leave it alone.
928 Collector
Did you say:
Engine out
Fuel lines out
Brake lines out
Radiator out
Sunroof out
Engine out
Fuel lines out
Brake lines out
Radiator out
Sunroof out
- Glass Off
2 Headlights
2 Fog Lenses
Sincerely,
Khaled Badr
- Glass Off
2 Headlights
2 Fog Lenses
Sincerely,
Khaled Badr
The doors should be removed to "trim" the paint, and then remasked and reinstalled for the final paint job. The doors were off for my body work and primer stages.
Nicole
Did the classic grey 928 get assaulted by a conspriacy of mutant pebbles? It seems as fast as I touch up rock chips on mine more appear....personally I think its like a union...you take one out and the union sends another one to take its place!
In most cases there is no need to "dissasemble" the whole car to repaint.....on the 928 removing both bumper cover should be a must....only because painting the rubber/plastic trim between the body and the covers looks stupid.....
Any "good" body shop can mask the rest of it off, sand it, prep it and paint it.......and no one will be the wiser.
paying them a little more to take extra time in the masking and sanding will pay off in the long run.
A full off frame (down the the shell(928)) is so not needed for a normal respray unless the body is totally wasted.....just find a good body shop......even Macco can do a good job if your not cheap....
In my opinion for less than a thousand bucks ( including warrenty) you can get a job done and no will ever know......
Take a real-real close look at new cars....their paint is not that good...really....even a new Porsche....the factory never makes it perfect...if you look really look you can see dips and the blemishes on most any paint job.
There a big differance between repainting vs restoring.....if you want to restore it say good bye to it for a long long long time...oh and bring lots of money
p
p
