Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Reload this Page >
Holbert Car cam update. Two MORE teeth found after 4 race weeknds after oil change
928 Forum
Sponsored by: 928 Specialists
Old 09-12-2005, 01:13 AM
mark kibort
mark kibort's Avatar
Default Holbert Car cam update. Two MORE teeth found after 4 race weeknds after oil change
Ok folks, looks like I may have to finally retire the Holbert racer after this next race. two more teeth were found on my magnet of the drain plug. it hasnt lost a tooth now in over a year. now, with only one cam potentially, with all its teeth. one or more cams are now missing more than one tooth on its sprocket. I told myself, that two would be the limit, and two next to each other would also retire the car for the season. going to pull the covers and see where it is.
I am thinking about using the 85 cams, as they are probably the same spec as what came in the car. however ,there is a need to modify the driver side exhaust cam, which does just happen to not be missing any teeth!! If i can verify that the cams are essentially the same, i may have to only change 3 cams which some have said are identical to the s4 cams as far as fitting in the engine.
Stan, you still out there?? how did the 85-86 cam conversion to s4 go from your cam grinder?
MK
mark kibort is offline
Old 09-12-2005, 04:09 AM
SharkSkin
SharkSkin's Avatar
Ouch.... best of luck with this... Keep us posted!
SharkSkin is offline
Old 09-12-2005, 08:10 AM
Thaddeus
Deer Slayer
Thaddeus's Avatar
Amazing that the engine still runs. Don't drive it any more until you replace those cams, OK?
Thaddeus is offline
Old 09-12-2005, 08:31 AM
[email protected]
Stan.Shaw@Excell.Net's Avatar
Hi Mark,
I haven't finished the project yet, as I acquired different heads with 968 valves. When I replenish my funding I will bring the heads back in (still chasing the honing/lapping process on the bored blocks too).
So many projects, so little time.... not to mention $
Stan.Shaw@Excell.Net is offline
Old 09-12-2005, 12:32 PM
Jim bailey - 928 International
Tick-tock, tick- tock, tick-tock, tick-tock.........BOOM ! it is not IF only when ! If you swap out the camshafts that is the extent of the "rebuild" but if you bend the valves then the heads must come off then you see the pistons then might as well do bearings then and then ...
Jim bailey - 928 International is offline
Old 09-12-2005, 12:35 PM
Chris
Chris's Avatar
You are sure pushing it, small fragments arn't always caught by the magnet and the mesh on the pickup is pretty large. When my tensioner pad failed at idle I found a fragment in the oil pump. At speed you would have no chance.
Chris
Chris is offline
Old 09-12-2005, 01:11 PM
Louie928
User
Louie928's Avatar
<snip>
MK
Mark,
I've seen companies that advertise that they can fix those broken teeth. I don't know the procedure they use. I doubt that the cams you have are '85/'86 grind. Your engine performs better that what those would do. More like a GT. Be careful about replacing 3 cams using a known type and leaving one of xx type. When you take the cam cover off, measure the lift of the intake cam. If 10mm, then they are same lift as GT cams which I think is the most lift for any stock 928 cam. S4 is 9mm, GTS is 9.5mm.
Louis Ott
Louie928 is offline
Old 09-12-2005, 01:48 PM
James-man
Super User
Mark,
With the risks you were taking, I had kinda figured that you were waiting for the engine to blow up so that you would have a reason to do a complete rebuild and maybe pursue a stroker - while you were in there.
It looks like really aren't waiting for Ka-boom and will take care of your issues after all. Had me fooled. Any others as well?
Anyhow, I hope you get your work done quickly and will not miss much track time.
James-man is offline
Old 09-12-2005, 02:54 PM
bcdavis
Super User
bcdavis's Avatar
He secretly wants an excuse to build a stroker...
bcdavis is offline
Old 09-12-2005, 03:39 PM
mark kibort
Thanks louis. yes, there is a 10mm lift and the hp curves are almost the same as rons GT. my hp is a little broader up top, but that could be due to the 85-86 grind that also has a 10mm lift.
im taking the covers off tonight to see what i got in there
thanks
MK
Originally Posted by Louie928
Mark,
Louis Ott
Old 09-12-2005, 03:57 PM
mark kibort
nice!!!! great!!! Now what??????
Old 09-12-2005, 04:48 PM
IcemanG17
Super User
IcemanG17's Avatar
Mark
Scary....gotta crack it open and take a look!! Didn't it slip a T-belt a while back?
Brian
IcemanG17 is offline
Old 09-12-2005, 05:10 PM
mark kibort
No, these are the same two teeth as i found them on the plug
mk
Originally Posted by Sterling
is that 2 more in addition to the ones you posted about yesterday?
Old 09-12-2005, 05:49 PM
M758
Super User
M758's Avatar
Mark,
take the before you replace the cams take them out and check them. You have a special car and I would not be surprised if these cams were somewhat unique. They could be off the shelf ones, but it would be better to know for sure.
M758 is offline
Old 09-12-2005, 05:57 PM
928SS
Road Warrior
928SS's Avatar
knowing mark's luck - he could finish the season w/those things.... if it were me, I'd have the Tbelt wrapped around the torque tube and the pistons sitting next to me in the pass seat, etc...
928SS is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
