928 Forum 1978-1995
Sponsored by: 928 Specialists
Hot auto shift knob
Old 09-11-2005, 12:23 AM
Ron_H
928 Barrister
Ron_H's Avatar
No, it doesn't sound right. Does it ultimately lock into place?
Old 09-11-2005, 12:59 AM
m21sniper
m21sniper's Avatar
Mine did the same thing from day 1 too Ron.
What i did was pull the center console and lay a big double thick sheet of aluminum foil in there(with a slot cut out for the shifter lever).
It deflects the heat back down away from the cabin.
My window switches used to get so hot at operating temp. they'd almost literally burn you to the touch, now even on hot days i can actually touch them without frying my fingers, lol.
Old 09-11-2005, 01:01 AM
m21sniper
m21sniper's Avatar
"forgot to mention when I stop the car and put the shifter in park the car will roll several inches if it's on a incline in park!!!.
Does that sound right?"
That's pretty common on most cars. Apply the P brake before you put it in park.
Old 09-11-2005, 01:07 AM
Ron_H
928 Barrister
Ron_H's Avatar
My switches get that hot too. I hate it and it is not acceptable for a GT car.
I may try the aluminum foil fix because I may never get around to pulling the transmission to fix the parking pawl. The console is a quick remove item and a lot less trouble than removing the torque tube and foam pad.
Old 09-11-2005, 01:25 AM
DALEZPLACE
DALEZPLACE's Avatar
Has anyone ever actually tried the foam idea ?? Reason I ask is because concerned if foam could become toxic and flammable if exposed to temps near cats ? Correct me if wrong but isnt it possible for them to reach almost 5000* ??
Old 09-11-2005, 02:22 AM
DANdeMAN
DANdeMAN's Avatar
I also have a hot console and I have new mounts on the car, so after 21 year the pad is capout I guess. But my AC is working perfectly. I'll probably install some sort of sheald or insulating material sometime in the future...
Old 09-11-2005, 02:49 AM
m21sniper
m21sniper's Avatar
Ron, the aluminum foil actually works really well.
I'd say the temp of my window switches dropped a good 40 degrees F after the fix!!!
Yanking the cat helped too, but a lot of heat still comes up through that area. I just installed new mounts a few weeks ago, and while it helped to cut down the heat(especially the heat that seeps up out of the ash tray), the aluminum foil actually had a significantly bigger impact IMO.
Heh, there you have my ghetto tip of the day.
Old 09-11-2005, 03:03 AM
Ron_H
928 Barrister
Ron_H's Avatar
Dale:
The foam would be dispensed from a spraycan into the cavity above the factory foam insulating pad so the temperature of the air at that point should be less.
But to tell you the truth, I like Sniper's idea best, because the foil is removeable and replaceable if you ever need to get down in there. Example: to disconnect the shifter linkage without removing the torque tube and foam pad from below. The aluminum sheild could easily be removed to allow access and then replaced all in a few minutes to a couple of hours. And the fire danger is much less.
Old 09-11-2005, 03:17 AM
Shane
Sharkaholic
Shane's Avatar
Here is some info you guys with 86's might find interesting:
Recall thread one
Recall thread two
Old 09-11-2005, 03:25 AM
m21sniper
m21sniper's Avatar
This is a common problem on all MY 928s so far as i know.
Mine is an 83, and my ex partners 85 also suffered from the same heating of the cabin problems(his was almost entirely cured with new mounts though).
Old 09-11-2005, 04:34 AM
Ron_H
928 Barrister
Ron_H's Avatar
thanks Shane. Very informative. Mine has a heat shield, but it may be the old one. I'll check it out.
Old 09-11-2005, 12:15 PM
Gary Knox
Gary Knox's Avatar
Rich,
The "movement" of the car on an incline when the transmission selector is moved to P is common for this Mercedes transmission. It did that on 3 previous automatic S4's I've owned, on two MB 560's of the same era, and I expect it will happen on the '88 S4 I just bought from the Portland OR area. Just expect it (it's only 2-3 inches), or use the parking brake.
Gary Knox
West Chester, PA
Old 09-11-2005, 12:22 PM
Gary Knox
Gary Knox's Avatar
Anyone who uses foam for further insulation, be sure you DO NOT use the 3X expanding type. It has tremendous expansion force, and could dislocate some stuff!!!!
Gary Knox
Old 09-11-2005, 06:51 PM
RDS928S
RDS928S's Avatar
Gary,
ok-finally I don't have to spend money on another malady. I guess the parking brake will surfice !
I just dropped off the 928 at my shop. The trip took me onto a local highway for a very short distance. As far as the sluggish/lazy feel -I took snipers/dandeman's advice and kept it in 3rd gear. Man, the car really took on another life.
It had some serious grunt!!.
Thanks again for the thrust bearing/torque tube advice.
Rich
Old 09-11-2005, 07:12 PM
Ron_H
928 Barrister
Ron_H's Avatar
Rich, is your kickdown switch functioning properly? At more than moderate throttle in 4th, your transmission should kick down into 3rd. Particularly when on the freeway and passing another car, or getting on and off of the freeway, that 3rd gear kickdown should be immediate. May want to check your transmission fluid level.
Quick Reply: Hot auto shift knob
