928 Forum 1978-1995
Sponsored by: 928 Specialists
Turbo
Old 03-02-2007, 06:42 PM
  #61
MarkRobinson
MarkRobinson's Avatar
even a -6 is fine: Ballbearing turbochargers require less oil & many come & require oil restrictors to limit the oil flow through the bearings, otherwise the tolerances are too close. Precision requires a very small needle-size hole through the restrictor, so a -3 to the restrictor.
Old 03-02-2007, 06:43 PM
  #62
MarkRobinson
BTW: my 911 turbo has a 1st gen ballbearing turbocharger: the factory -4 line supplied so much oil, the mechanical oil scavenge pump couldn't come close to keeping up. Required a serious restrictor, but have 70k on that turbocharger w/o issue & w/o water-cooling.
Old 03-03-2007, 01:10 AM
  #63
UNTS1
UNTS1's Avatar
When is ur 16v Turbo system getting released
Old 03-03-2007, 06:25 PM
  #64
Gulpilen
Gulpilen's Avatar
Im only building one example of this and its on 32V.
Restrictor (good idea I will considor);
About oil to the turbo - as now 6AN with original adaptor to turbo and Ive got the 3 qt accusump on the line. I hope the pump manage it all. I have a 12AN back to the drain.
/Jonas
Old 03-04-2007, 12:42 AM
  #65
UNTS1
UNTS1's Avatar
sorry was talking to mark . As I am buying the 16v kit when it is released
Old 03-04-2007, 01:40 AM
  #66
Wade T
Wade T's Avatar
Here's an entertaining video about rear mount turbos:
http://videos.streetfire.net/search/...9000e3a63d.htm
Quick Reply: Turbo
