928 Forum 1978-1995
Sponsored by: 928 Specialists
Unpredictable Acceleration
Old Jul 18, 2005 | 12:56 PM
kraabel's Avatar
kraabel
Default Unpredictable Acceleration
86.5
I have good days and bad days with acceleration. Lately there have been more bad. Somedays I'll punch the accelerator and the car will jump off the line throwing the passenger in the back seat.
Recently she started to limp out of the start, only reaching a good kick once it hits 50 or more. There still seems to be some sluggishness at that level, but not nearly as bad as the starts.
It happens a lot when trying to accelerate on the freeway for using onramps from a stop.
Any suggestions on what might be the first thing to check out?
Old Jul 18, 2005 | 01:08 PM
Ketchmi's Avatar
Ketchmi
1. MAF. Give John Speake a holler, I'm sure he can help you out.
2. Vaccum leaks.
Old Jul 18, 2005 | 01:17 PM
John Speake's Avatar
John Speake
Hi Kraabel,
Is it really intermittant, or does it seem worse when the temp is hot ?
How many miles on the car - anything over 80k and the MAf is probably due for repalcement.
Does the car idle steadily ?
Old Jul 18, 2005 | 03:26 PM
GlenL's Avatar
GlenL
Any relationship to the 95F afternoons we've been having?
Old Jul 18, 2005 | 04:39 PM
kraabel's Avatar
kraabel
104,000 miles. It's hard to tell about being effected by temp, because it's been so bloody warm her lately.
The car seems to have a great idle.
Yes 95 degrees yesterday working on a timing belt adjustment was something I would have rather not done.
Anyone got any good links for MAF replacement? That was my original thought.
Old Jul 18, 2005 | 07:16 PM
John Speake
If idle is good, that tends to rule out inlet air leaks, and points more to the MAF especially at 104k miles.
Here's a link... www.jdsporsche.com
Old Jul 18, 2005 | 11:24 PM
Rob M Budd's Avatar
Rob M Budd
Check your throttle cables. From the pedal all the way to the throttle body and from the trans, if its an automatic. Check adjustments and for any loose brackets and check for binding or places they might get hung up.
Old Jul 21, 2005 | 04:41 PM
kraabel's Avatar
kraabel
I pulled off the MAF last night, cleaned out all the contacts and checked them for voltage. Things seem to work just fine. I ran the car for a bit with it out and it seemed to work just fine, but actually ran a bit worse. During this test, I had both plugs undone. Was the sensor supposed to be plugged in?
That being the case, what else might I look at to improve my acceleration performance?
Old Jul 26, 2005 | 04:25 PM
kshipp's Avatar
kshipp
I have good and bad days like this as well, but I haven't investigated why (yet). From what I've read, my MAF may be suspect. I have more research to do before I make any assumptions...I haven't tested it at various temps to determine if it only happens while hot, etc. It idles steady and has 82k miles on it.
Old Jul 26, 2005 | 04:32 PM
Niels Jørgensen's Avatar
Niels Jørgensen
Considering John Speakes track record and low price for testing the MAF, that would be my first shot. (It was probably my 152nd when I had the hesitation bug, I still wish it had been my first ...)
Old Jul 26, 2005 | 05:01 PM
John Speake
Good to see you're still lurking here, Niels !
I do offer a "try before you buy" service in the USA as the logistics of testing are more difficult. If you buy one of my MAFs that fixes the problem, I can always let you know what the calibration was of your old unit when it gets back to me.
Regards
Old Jul 26, 2005 | 06:29 PM
kraabel's Avatar
kraabel
John-
I'd love to take you up on the try before you buy offer. What's the process?
Old Jul 27, 2005 | 05:58 AM
John Speake
Hi
You basically Paypal me the 350USD plus 100USD core charge. I send you a rebuilt MAF. If it doesn't fix the problem, then you return the MAF undamaaged to my agent in NY. I will then refund your 450USD less my out of pocket expenses - about 30USD.
If you keep the rebuilt MAF, then when my agent receives your old MAF I refund your 100USD core charge.
Regards
By Michael S. Palmer | 2026-06-09 16:47:52
