Rough Ride
Rough Ride
1896 928 S I know this is a sports car. Just took a trip from Nashville to KY & felt every crack in the road. Above 65 mph this is no joy to ride. any input
Could be several things. If it really is an 1896 model, the wheels are wood and the tread may be hand formed steel around the wheel. Those things are rough riding, but the smell of the horses in front make you forget the ride. Odds are it is really a 1986 928
One problem could be weak springs and too low ride heigth. Setting the suspension properly and a new set of springs/shocks may change everything.
Another issue could be tires. If it has 18 inch tires with high pressure tires, that is just the way it is.
USMarine
Might be those wood and steel wheels of the 1896 version.
You guys are too funny.
Check your air pressure. The owners manual recommends like 40PSI. I'll go 35 and maybe 30-32 to soften the ride. I've got stiffer shocks and springs, but softening the tires will do a lot for you.
The right tires make a big difference as well. This is even more true if you have really old tires of certain brands. The nice thing about old tires is that they are hard and stiff and make it easier to spin the tires or lose traction. 6 or 7 years is old for a tire.
1. Tire pressure ~34psi
2. Shocks
3. Motor mounts
4. How loaded down were you
5. Kentucky Department of Transportation Highway Resurface Program
Cheers,
Dave
Yes it is a 86.5,why do they ride rougher.
You should check the brand of the shocks and look at the springs. It is very possible that some prior owner installed Koni shocks and performance springs to FIX the "too soft ride".
I have noticed that with the tires set to spec pressure in the rear (44 psi) the ride gets worse and the traction gets worse too...personally I run 35-36 psi all the way around...better ride and better traction! If you have a really high mileage suspension (think 150K+) then it might be time for some new shocks-springs & an alignment ride height adjustment! Pricey but makes a world of difference to a car with worn suspension!
Brian
Brian
