928 Forum 1978-1995
Sponsored by: 928 Specialists
PET 5 question
Old 05-13-2005, 08:49 AM
jim morehouse
jim morehouse's Avatar
Bert,
The content of the PET6 and the pdf version of the PET6 is, as far as I can tell, the same. The difference is that the PET6 is a program that must be installed on your computer and it requires you to set your screen resolution to 1280x1024 or you can't see the 'buttons' to navigate around the program. Plus, a small percentage of people have problems installing it on their machines....usually cured by multiple attempts.
(for the archives: you can get around the resolution issue w a program like 'winspace light' which allows you to pan around the screen )
The pdf version has no such resolution requirements or flakiness and opens in adobe reader so you can also use the search functions. You can get it from your dealer, as mentioned, or 928specialists also carries it and is likely faster.
Jim
Quick Reply: PET 5 question
