Fuel injector question
Hello!
Has anyone a technical documentation about original fuel injector on a S4 1988?
0280150760 Bosch
Is it high or low impedance?
/Jonas
0280150760 Bosch
/Jonas
Hej Jonas,
I think they are considered to be high impedance.
Each injector should be around 14,4 Ohm and 4 on each side are connected in paralell and connect to the same pin at the EZK.
Cheers/Peter
Cheers/Peter
Hello Peter!
OK!
Found these at summit:
Brand: Accel
Product Line: Accel Fuel Injectors
Injector Advertised Flow Rate (lbs/hr): 40
Injector Advertised Flow Rate (cc/min): 417
Quantity: Sold as a set of 8.
Injector Impedance: 12.0 ohms
Driver Type: 12V saturated circuit
Overall Height (in): 2.880
Seat to Seat Height (in): 2.270
Manifold O-Ring Outside Diameter (in): 0.573
Fuel Rail O-Ring Outside Diameter (in): 0.574
Outside Diameter (in): 0.943
Injector Plug Style: Bosch/Amp Style
But they have another impedance 12 Ohms, is that ok for my ECU?
Vi ses!
/Jonas
OK!
Brand: Accel
Vi ses!
/Jonas
Jonas,
If you want aftermarket injectors, these Design II Bosch units are a match for the S4 - at a flow of 19#/hr: They have 4 injection orfices with a disc distributor vs a single hole - pintle type. You must have a set of 928 specific manifold O-rings. eg. http://cgi.ebay.com/ebaymotors/ws/eB...954014902&rd=1 . Use the link to search under Bosch or Ford - many to be found at reasonable pricing.
Unless you have done some amazing mods, the Accel units noted @ 40#/hr are far too large : I believe the super charged engines are using 24 - 30#/hr.
The LH will idle even though richly with 36# injectors... As you have a race car... Why don't you just put in a MOTEC or TEC III..? this way you can control everything with one computer...
just my .02
just my .02
Motec
Read earlyer threads about motec and it seems to be good and expensive. One guy wrote like this "first they try with laborating on different fuel/boost (or something like that) and the engine broke and then they get motec on next project". Got scared Imed.
I would like one sheet before I buy a motec "This is how you do when to put it in a 928 and so forth"....
Wich model (wich one is the best for turbocharge)?
To by sush a thing for ex on e-bay it would be from a company with garantees.
I will try to get more info about motec but anyone who has info is free to share...
Any other brand wich has been tried out?
/Jonas
/Jonas
"Why don't you just put in a MOTEC or TEC III..? this way you can control everything with one computer..." - 928Blau -
Most have a life other than their Porsche. Do you realize the effort required to convert
to another fuel & ignition system, i.e. forget the installation part which is minor
compared to the dyno time to set the fuel & ignition maps & solve ALL the running
problems?
problems?
Dedicated to my cars..... , do ask a college at my work - try the first you meet.
In my garage 2 guys have aem box in their M 3000 gt. Is the difference big in mapping?
/Jonas
/Jonas
