928 Forum 1978-1995
Sponsored by: 928 Specialists
Awesome Pilot Bearing Puller (image intense)
Old 11-22-2004, 02:06 AM
JKelly
JKelly's Avatar
Thumbs up Awesome Pilot Bearing Puller
Check it out......
After going to Lowes, Harbor Freight, and every "Auto Parts" place in town, I finally decided I could make a bearing puller a lot faster (and cheaper) than I could find one to buy.
I used a decent sized square bolt, drilled a hole through the metal shims to attach a carriage bolt, and ground the head of the carriage bolt to where it just fit through the pilot bearing. I used a nut to grip the pilot bearing and turned the two square bolt nuts to apply force evenly on either side until the bearing popped out. Piece of cake
Old 11-22-2004, 02:24 AM
G Man
G Man's Avatar
Wish I had a 5 sp to try that out on!
Old 11-22-2004, 02:50 AM
Tony
Tony's Avatar
Gotta love it!
Old 11-22-2004, 04:27 AM
SharkSkin
SharkSkin's Avatar
Nice job John! Put that one in with the other fancy Porsche tools.
Old 11-22-2004, 05:18 AM
Garth S
Garth S's Avatar
That is slick!
Old 11-22-2004, 07:44 AM
Jim R.
Jim R.'s Avatar
Very cool. I've gotta save this for future reference. Hopefully I won't need it anytime soon, but that definitely works.
Jim R.
Old 11-22-2004, 09:46 AM
Fogey1
Fogey1's Avatar
Very ingenious. Thanks.
Any chance of another pic - with a ruler underneath?
Am I right that the pull is just slightly off-center because the carriage-bolt lip has to fit through the bearing and then move over? Is that the reason for the nut on the carriage bolt, to keep the pull on the bearing as square as possible?
Old 11-22-2004, 11:04 AM
JKelly
JKelly's Avatar
Yes, the pull is slightly off-center and the nut keeps the pull on the bearing as square as possible, plus it keeps the carraige bolt from slipping; that way you don't have to have your other hand up there trying to use a screwdriver or vice grips to keep the carraige bolt wedged into place. The nut doesn't have to be tightened much.
Step 1. Put the carraige bolt and nut on the bearing.
Step 2. Slide the square bolt on and spin the other nut on to hold it.
Step 3. Turn the square bolt nuts, alternating sides, until the bearing pops out.
When the bearing gets close to popping out, be sure to hold the square bolt; otherwise it may surprise you and land on your face like it almost did mine.
Old 11-22-2004, 12:25 PM
heinrich
928 Collector
heinrich's Avatar
Thanks ... I'll make one and use it this week ...
Old 11-22-2004, 08:55 PM
UKKid35
UKKid35's Avatar
Looks neat!
I bought the Harbour Freight pilot bearing puller after studying the specs. When I got it home I found the three "prongs" were too big to fit through the pilot bearing (the specs were wrong), however it could still be persuaded to work with just two and the other folded out of the way.
Old 11-22-2004, 09:29 PM
T_MaX
T_MaX's Avatar
I really like it, U Da man!
Old 11-23-2004, 11:06 AM
JKelly
JKelly's Avatar
Thanks for the compliments everyone!
Originally Posted by UKKid35
Looks neat!
I agree, the Harbour Freight puller (around $16) states it will fit a 1/2" inner diameter, which should just about fit the 928 bearing. There is no way the HF puller even comes close to fitting.
Heinrich, if your actually going to need one soon, I'll toss this in the mail and send it to you.
Old 11-24-2004, 12:54 AM
heinrich
928 Collector
heinrich's Avatar
You're da man John thanks :-) I have the bearings in-hand .... engine is out too.
Old 11-24-2004, 01:34 AM
Red UFO
Red UFO's Avatar
John,
Great piece of problem solving. When my pilot bearing was toast I had simular ideas but couldn't visualize in my head what you could and made real. Congrats!!!
Just put a Sean Bearing Puller on ebay or, $150 bucks on 928 int! and collect the royalties.
Old 05-25-2006, 09:19 PM
UKKid35
UKKid35's Avatar
No way at all it fits the 928 bearing. I used one prong (not two as I said earlier) and an 8mm allen key.
Quick Reply: Awesome Pilot Bearing Puller (image intense)
