H3 LED from Philips has a ground Problem!
Thanks for posting this! I ordered and just received this bulb from EU for my fog lights. Did your remove paint from the mating surface facing the LED?
Last edited by RTK; 01-26-2024 at 01:51 PM. Reason: include photo, ask question for clarification
Electron Wrangler
I don't see how it isn't already well grounded through the retention clip? You will also need to re-route the positive to be free of the clip compression.
Alan
Alan
davek9 (01-28-2024)
Alan, the clip can ˋt reach the bottom of the paint free area because there isnˋt enough room in the nose area.
The picture is only for illustration, on the car I had the wire on the other side.
Hmm.. I watched a video yesterday about a cheap spot-weld tool for use in DIY building of replacement manufacturer specific battery packs.
It might be possible to take a similar approach and spot-weld a nickel strip to a small bare patch, around the base of the bulb (and back onto itself) to facilitate good contact?
Video on cheap spot-welding tool..
Plus the tool looks like fun
These go right in, fit, and work great.
Calais Extremely Bright H3 LED...
Have them in my 928 for the gigs and aux hi-beams and in our 944 S2.
Will go to 6000K HID headlights when one of these wears out
Parking light since fixed
RTK (01-27-2024)
^^^ Petza914, I really like the looks of that garage!
Cheers
Cheers
Petza914 (01-29-2024)
