Alternative for 928-110-652-02 hose to vacuum valve? (1986)
I am looking for an alternative for NLA 928-110-652-02. It is a hose with different diameters at each end. It is front of engine and runs between the control valve (944 110 429-00) mounted to the crossbar and the vacuum valve (928-110-429-08) that sits beneath/beside the washer reservoir neck. In the diagram below it is #21 and runs between #18 and #20.
Anyone know an effective alternative or source for this part? Mine has split so needs to be replaced.
Thanks,
Matt
Thanks,
Matt
Basic Sponsor
What is the ID of both ends of the existing hose?
Hi Roger, and thanks.
The hose is about 18 inches with IDs of 0.50" (13 mm) and slightly over 0.25" (7 mm).
The hose doesn't appear to be moulded.
Matt
Matt
Looks to be one of the #21's.I think it is the lower on in the diagram that looks like my grandfathers pipe.
Darklands (10-23-2023)
i just dealt with this issue myself
I purchased 2 different size hoses that fit the 2 ends, then went to the hardware store and got a brass barbed hose fittings that fit the hoses and had a threaded end where they threaded together
I then spliced that into the center of the hose run
Matt
