Coolant leak
#46
If the water pump was jammed you would have no cooling and the timing belt would scream like hell with potential to rip it apart. You stated there was a small leak so no surprise there is a pump problem but I am puzzled as to how you did not report strange noises or high temps. Was the outboard face of the timing belt damaged at all?
Fabien92 (12-03-2023)
#47
No strange noises or high temps.
The outboard face of the timing belt is clean.
I stopped the 928 two months ago waiting for the parts and time to change the timing belt and water pump. I think that the old water pump jammed when the 928 was sleeping !!!!
For sure, I had a pump problem before it jammed definitely.
#48
Interesting - never heard of that happening previously! The only thing I can think of would be if the coolant got behind the seal thus the leakage and somehow initiated a corrosion eent of some kind that cuased the thing to seize up.
Does your new pump have a plastic impeller or a steel one?
#49
The metal impellers, with water pump failure, have been known to damage the engine block.
OTOH, the plastic impeller, with water pump failure, makes the engine hot.
#51
Unfortunately, I think that you have gone backwards in relation to your replacement choice of water pumps in the water pump evolution chain.
