Temp and Fuel Gauge all bouncy..
I did a pod refresh, new bulbs, new foil..cleaned the connection ends all studs and nuts..everything..and I still have these two gauges that just don't work right.
Pod's gotta come out again, but what should I be looking at this time?? Nothing could possibly be cleaner...I wouldn't think... https://cimg4.ibsrv.net/gimg/rennlis...bacfeb9e2.jpeg https://cimg5.ibsrv.net/gimg/rennlis...bc27cc985.jpeg https://cimg6.ibsrv.net/gimg/rennlis...e0e4a45c3.jpeg |
If it wasn't like that before you worked on it, that probably eliminates the gauges and points to a connection issue.
Both of those gauges come through "plug A"...that would be where I would check, first. Sometimes a reach behind and a wiggle on the connector will cure things. |
I had an issue with my fuel gauge where the wire from the sender under the pod was a bit corroded. A wiggle fixed it as suggested above.
Couldn't hurt to hit the pins with some deoxit and a q tip. |
I would suggest to put the D 100 on the connectors only ,
spraying the foil with the D 100 can cause the metal tabs to de laminate . BTDT |
Originally Posted by GregBBRD
(Post 18906411)
Originally Posted by Mrmerlin
(Post 18906504)
I had a similar issue on my 951. Noticed that the gauge (temp/fuel) were only bouncy when I turned the lights on. Cleaned battery grounds and checked brown wires. Not sure which random ground cleaning cured it, but that was it.
Remove the stacked ground wires down by the pedals and clean them and the point where they attach.. Clean the main alternator ground. That oscillation in the needles is sometimes from the rotation of the alternator.
(Post 18906504)
If multiple gauges are affected in the same way at the same time its a grounding issue - focus there .
Alan |
I'm not going to say that it isn't a good idea to clean all of the main grounding points, however I kinda doubt that removing the cluster and working on it is going to suddenly cause a connection issue at a remote bolt though grounding point.
.....Definitely not where I'm going to tell one of my guys to go, first. Now if the problem existed before removal....that's a whole different story. |
Originally Posted by Alan
(Post 18907096)
Alan Just those two, were like that before and after. I cant believe I didnt touch the ground point back there... |
I'm not talking about all the ground points or even just the chassis ground points. This IS clearly a grounding issue from the symptoms - I'm not just guessing. Look at the chassis grounds specifically for the pod and also all the ground connections inside the cluster to the gauges. It must be a common point to all the gauges affected. As Greg says it is most likely something you touched - quite possibly internal to the cluster. On re-reading it seems you've had this a while - however its still a local issue to the pod grounds.
Alan |
(Post 18907811)
Alan Yup..we're on the same page. Which plug is "A"? |
Allen, just where are the pod grounds located? Just asking for future refs.
