928 Forum 1978-1995
Sponsored by: 928 Specialists
Convince me I can do my '78's water bridge gasket myself
Old 09-13-2024 | 07:23 PM
  #46
Lawrencejuliano's Avatar
Lawrencejuliano
Originally Posted by Mrmerlin
Glad you got the bolts out,
now when you install them use loctite 567 PTFE paste sealant,
this will prevent coolant from wicking into the threads .
use it also on the water pump bolts.
NOTE make a thread chaser from one of the used bolts cut three flutes into the first few threads,
then add some PB to the hole,
and slowly in and out the screw into the threaded portion. dont force the screw,
dont use a tap as it can remove metal.
Thank you again Stan. In reading a few of your other posts on the topic, I also need Dow 111 for the center O-Ring and Drei Bond 1209 for the oil filler and water bridge gaskets. Are Hondabond or Permatex 22071 Water Pump & Gasket Maker suitable substitutes for the 1209?
Old 09-13-2024 | 08:41 PM
  #47
Mrmerlin's Avatar
Mrmerlin
Team Owner
I use either Hondabond or the dreibond 1209 nothing else
Lawrencejuliano (09-13-2024)
Quick Reply: Convince me I can do my '78's water bridge gasket myself
