928 102 120 TVD - Ultimate 928 Torsional Vibration Damper (TVD) - ADVANCED PURCHASE -
Basic Sponsor
3
30 Units available for advanced purchase - expected availability June 20th 2022
Advanced Purchase here - https://928srus.com/products/928-102...ion-damper-tvd
Ultimate 928 Torsional Vibration Damper (TVD) - 78 to 95
Features & Benefits:
1) Interference fit for Improved Vibration Transfer
2) Reasonable Installation Temperature
3) Fool Proof Design - Can't be Installed Backwards
4) Permanent Indentation showing Keyway Orientation
5) Hub comes Pre-lubed with Anti-seize Compound
6) Easy Removal using custom removal Tool (included).
The original Porsche Harmonic Dampers are no longer available.
The Hub Kit was created by "GEZA" as a clean sheet design. The ATI Damper (917020) should be purchased separately from an authorized ATI reseller. This insures the damper is covered under Warranty. International buyers may prefer to purchase the ATI Damper from 928sRus directly (ATI Warranty will be voided). Email for price and availability.
Current price of the ATI Damper 917020 circa $280.
https://www.jegs.com/i/ATI/085/917020/10002/-1
https://www.summitracing.com/parts/ati-917020
The following 4 users liked this post by ROG100:
Do manuals have this also? Do the originals wear out?
Inventor
Don't forget to get Torque Plus TP40 and TP45 sockets!
The following 4 users liked this post by PorKen:
Bumped - for those contacting me about availability.
I am currently having my Timing Belt Service done on the 6.5L stroker on my 86.5 Automatic. Seems like as good a time as any to put in an ATI Super Damper.
Can anyone tell me whether it matters that this is a stroker motor vs. a stock motor? I am guessing it will be better than the original OEM damper that's on there now.
Thank you, in advance!
Basic Sponsor
Nice to see that the latest alloy hub design from Geza also reduces weight significantly.
Notice the corrosion already attacking the steel hub - not pretty.
