S4 oil pan/ sump onto a 4.7
Hi guys,
Does the S4 sump fit onto the 4.7? I notice they both have different part numbers, but are there any differences?
My sump has a few cracks in it from P.O. hits and need to replace it, I have found some S4 ones.
Adam
Adam
Make sure the oil pan you want to use has the oil return hole covered with a bolted on plate. You are probably going to want that for your 4.7L. I don't remember which year they did away with the hole.
Received 1,542 Likes
I have a extra early oil pan. Clean, ready to pack and ship. $75 + shipping.
Edit: Australia. Never mind. Not worth shipping it.
ANF (07-12-2019)
If your early pan has the screen, you will need to drill and tap the holes in the S4 pan.
Team Owner
dont forget to transfer the little rubber isolater so the hot wire is kept from touching the pan,
this will be obvious once the starter is wired
Thanks guys.
