928 Forum 1978-1995
Sponsored by: 928 Specialists
new 928 owner
Old 07-06-2019, 09:56 PM
joekuntze
joekuntze's Avatar
Default new 928 owner
digging into my 88 5 speed as most of you know restoration is 75% cleaning and repainting but the other 25% is listening and learning so i dropped the cradle for the fuel tank to patch a rust through spot and ordered new fuel hoses from the tank to the pump and from the filter to the hard line as well as a new filter was derusting the hard fuel line in passenger wheel well and noticed another hard line behind the fuel tank that wraps around behind the bumper and ends in the middle of the car connecte to nothing doesnt seem kosher
also near passenger tail light there are two wires wrapped in black prtective plastic one white and the other red or brown and there is an empty hole in my bumper cover above the liscense light righ below the latch mechanism any help appreciated thanks in advance
Old 07-06-2019, 10:14 PM
Landseer
Landseer's Avatar
Hi Joe, welcome.
Try to posted some pictures.
A little hard to follow, but sounds like you are concentrating on back of car. Its possible a carbon canister related vent that is open ended, carbon system is behind pass side wheel well.
Pics of engine compartment would help. There are a series of fuel hoses in there that may need updating. Takes a special higher pressure hose.
With these cars it's best you get a copy of the shop manuals and parts diagrams and not guess. 928srus sells CD set that has some extra docs that take some of guesswork out. 928 is better documented than a Silverado pickup truck in my experience.
Chris
Old 07-06-2019, 10:19 PM
The Forgotten On
The Forgotten On's Avatar
That line that connects to nothing is just a vent line. You can ignore it.
The hole in the bumper cover is for the tow hook if you ever need to use it.
And those two wires are probably for the rear fog light that isn't used in the North American market. You can ignore them as well
Old 07-06-2019, 10:57 PM
joekuntze
joekuntze's Avatar
thanks all printingworksohop manyal off internet but havent gotten to that plan on doing intake refresh ala dwayes garage and replacing front lines working my way forward
Old 07-07-2019, 06:51 PM
polecat702
Vegas, Baby!
polecat702's Avatar
When ya sober up, you'll hate yourself in the morning! Been there and done the same thing. Welcome to the tank!
Old 07-07-2019, 08:49 PM
NickTucker
NickTucker's Avatar
Nice to see another '88 5 Spd join the tank!!
Welcome Joe!
Old 07-24-2019, 12:10 AM
joekuntze
joekuntze's Avatar
ok thanks for all the help have repaired rust under rear bumper cover and passenger rocker cover, repaired fuel tank cradle and replaced fuel hoses and gas filter gottten rear wiper repaired and ordered new hatch lock upper and lower
couple of tragedies accidentally drilled a 1/8 inch hole in the rear bumper cover (dont ask) and crushed the upper hatch lock (who knew they were pot metal 400 bucks ouch
the next up is intake refresh, timing belt an water pump thanks dwaynes garage
thanks for all the encouragement and support
Old 07-24-2019, 06:04 PM
SteveG
SteveG's Avatar
Until you post pics of car,noneof this hashappened. gooodluck.
ohandwelcome.
Old 08-03-2019, 11:59 PM
Larry 928
Cruisin'
Larry 928's Avatar
Hi, great work. Where did you get the fuel hoses for the fuel tank. Three hoses !
Thanks, Larry
Old 08-04-2019, 12:26 AM
77tony
77tony's Avatar
Thanks, Larry
Call Roger on Mon: 817-430-2688 www.928srus.com
Old 08-04-2019, 03:40 AM
928 GT R
928 GT R's Avatar
Received 4,914 Likes on 1,900 Posts
This
Old 08-04-2019, 07:58 AM
beran earms
beran earms's Avatar
THREAD
Old 08-04-2019, 08:14 AM
Red Flash
Red Flash's Avatar
.....IS......
Old 08-04-2019, 08:58 AM
merchauser
merchauser's Avatar
USELESS.....
Old 08-04-2019, 12:21 PM
Ninespub
Ninespub's Avatar
WITHOUT..........
Quick Reply: new 928 owner
