Ground Wires
Ground Wires
Fooled with the grounds at the back of the V (VIII Engine Power and IX Engine Electronics) and my engine came back to life from a no start condition. Would like to pull the bolts and do a better job of cleaning the contacts. The driver side is easy enough to get to but the passenger side is a bit tight. What needs to come out besides the AC heater valve in order to get good access? Seems like the fuel line leading into the rail.
Thanks,
Steve
928 S4 Auto
Thanks,
Steve
928 S4 Auto
Team Owner
whatever is in your way remove.
you can get the bolts out for both sides from the driver side,
if the hood is off things get even easier
