928 Forum 1978-1995
Sponsored by: 928 Specialists
Nut: Brake Booster - Brake Master Cylinder (picture)
Old 06-13-2019, 04:36 PM
wopfe
wopfe's Avatar
Default Nut: Brake Booster - Brake Master Cylinder (picture)
After i got good advice this week on replacing the master brake cyilinder i started with the removal today. Went great until i found the drivers side nut, which is virtualy inside the fender, does anyone have advice on a tool, procedure for this? I got a socket on there but can't get enough power on there to brake loose (yes i am blasting the thing with penatrating oil). Any experience on how to do it? I stopped being afraid of f*cking up the nut.
Thanks in advice!
'79 red euro manual.
Old 06-13-2019, 05:25 PM
Bigfoot928
Bigfoot928's Avatar
Old 06-13-2019, 05:53 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
There's a handy Cummins 13mm injector wrench that's all but designed specifically for this duty. You can find them at Toolsource https://www.toolsource.com/injector-...-p-114464.html and I'm sure there are similar at other places. There are certain 13mm and 1/2" offset distributor wrenches that may also work. These are often referred to as "offset" or "angle" wrenches.
Old 06-13-2019, 07:22 PM
Bigfoot928
Bigfoot928's Avatar
Old 06-15-2019, 03:25 AM
wopfe
wopfe's Avatar
Thanks for the quick reply’s looking for one of these in the Netherlands now! Cheers!
Old 06-15-2019, 05:51 AM
StratfordShark
StratfordShark's Avatar
In UK they are referred to as “half moon spanners”. Not usually seen on shelf at retail tool places, but widely available online.
Old 06-15-2019, 02:12 PM
wopfe
wopfe's Avatar
It worked out by using 2 cutting 2 cheap tools. It took me 1 hour to get it out. 7.23 hours to get it in what a b*tch of a job...
but it worked out well! Drinking a beer with sore fingers Thanks everybody!
Old 06-15-2019, 05:19 PM
Jason89s4
Jason89s4's Avatar
Good work! Google "stubby metric wrench set." You will find a lot of tight-space uses for these on the 928.
(FYI, if you thought the M/C was tight....try changing out the booster!)
Jason
Old 06-16-2019, 12:47 PM
Ad0911
Ad0911's Avatar
Now this is strange! I live in NO too and I too have a my 79. My MC has threaded holes with bolts coming from the pedal side of the bulkhead. No nuts.
Old 06-16-2019, 01:03 PM
Bigfoot928
Bigfoot928's Avatar
Originally Posted by Jason89s4
Good work! Google "gearwrench stubby metric wrench set." You will find a lot of tight-space uses for these on the 928.
Jason
fixed it for ya
Old 06-16-2019, 01:33 PM
Jason89s4
Jason89s4's Avatar
Ha Sterling!
It turns out that is the exact brand I have...just didn't remember when I posted.
Jason
Old 06-16-2019, 01:45 PM
Koenig-Specials 928
Koenig-Specials 928's Avatar
Stirling/Jason: What is that angled/pivoted gear wrench from Craftsman called. I've never seen that before.
Old 06-16-2019, 02:37 PM
Bigfoot928
Bigfoot928's Avatar
They aren’t craftsman. They are gear wrench brand.
Old 06-16-2019, 02:46 PM
Bigfoot928
Bigfoot928's Avatar
Just looked at them they are craftsman. Bought them back in the day when the name meant something.
Old 06-17-2019, 07:00 AM
Koenig-Specials 928
Thanks Stirling. I think I'll get a set of those. They look handy
Quick Reply: Nut: Brake Booster - Brake Master Cylinder (picture)
