“Flex Seal” rear liner fix update
When we did the updated maintenance on the GT the rear wheel liner had started to deteriorate like so many later model year wheel liners. Dave (worf928) suggested using “Flex Seal” rubber spray to try and safe it. Nothing to loose, so I gave it about 10 coats (2 cans worth) of Flex Seal waiting about 24 hours between each coat. The liner looked good and went back in with no issues.
I have put about 300 miles , mostly highway, on the GT this year now and the liner looks as it did when we installed it. Next week I go to Camp 928 for a round trip of about 500+ miles so we will see if it continues to hold up. before and after pix below https://cimg0.ibsrv.net/gimg/rennlis...d75abce41.jpeg Most of the cracking was on the two ends of the liner https://cimg3.ibsrv.net/gimg/rennlis...1f72baf49.jpeg Front side of liner was worst https://cimg1.ibsrv.net/gimg/rennlis...6005180c3.jpeg Liner all sprayed and ready for install https://cimg4.ibsrv.net/gimg/rennlis...b01ba47bf.jpeg Looking good after first 300 miles https://cimg8.ibsrv.net/gimg/rennlis...61d0d5163.jpeg No cracks have opened and nothing has “chipped” off. |
Excellent report Bob. That looks pretty good, and should help a lot of folks.
That's good news! :thumbup:
Very clever!
That's great to hear. I have had mixed results in the past. When it worked, it worked well.
When I did the job, I first cleaned the liner surface with a degreaser, then took a scotch pad and scrapped the surface up and cleaned again before spraying the flex seal on. I was hoping to get better adhesion that way. It also said to wait 24 hours between costs to make sure rubber fully cured/dried and no volatiles left before next coat. Time will tell!
Bob & Dave,
Thanks for thinking of and posting this. I'll preemptively remove and spray the GTS liners because the they are original and un-cracked but they feel a bit stiff compared to the new ones on XX8. This technique may help them last longer and will reduce a bit of road noise. |
Originally Posted by 928 GT R
(Post 15904162)
Bob & Dave,
I'll preemptively remove and spray the GTS liners because the they are original and un-cracked but they feel a bit stiff compared to the new ones on XX8. |
Good thought! Will do...
Update with 3000 miles on the liners
Just checked the “flex seal” driver side rear liner after 2400 miles trip down and back to Atlanta. Most driving cruising 75-80 and temps were 90 degrees plus for most the drive. Total mileage on the liner now ~3000 miles. Liner looks fine, no cracks opening up or liner peeling, essentially looks like when installed.
I’ll probably take the passenger side out and coat that also to preserve it for as long as I can. Should make a commercial for this stuff! 👍 https://cimg2.ibsrv.net/gimg/rennlis...fb3f5f2b4.jpeg Front of liner https://cimg1.ibsrv.net/gimg/rennlis...2525fd4ac.jpeg Rear of liner |
Excellent!
Great News.....
Impressive fix and looked great when I saw it on your GT. When I got home I planned to use the same fix on a pair of GTS liners. Despite my best efforts, they just crumbled when I touched them. 😭
https://cimg7.ibsrv.net/gimg/rennlis...7822e2bc4.jpeg |
Originally Posted by Range Rover
(Post 15967412)
:icon107: |
(Post 15967412)
