jeff spahn |
06-06-2019 12:28 AM |
Front of Engine Harness
I just completed putting my new Front of Engine Harness (FOE) on from Sean Ratts. It wasn't really a bad job (did, whilst draining the block pull out threads on the block drain bolt but that's another story). The crossmember cable clamp really sucks to get to, as I have told others. The front of engine clamp through the timing chain cover sucks as well. The rest of the running of the wires is really no big deal. While you are in there, it gives you a chance to really check around the engine bay for problems (none that I didn't cause found!). Anyway. Car started right up as it should and the voltage gauge now is reading correctly and corresponds to the jump post voltage on a multi meter. Nice to know I should be good to go for another 30 years.....on this part.
