Boring the 4.7
Archive Gatekeeper
If the question is to _only_ use 5.0 pistons, then the answer is no. The question is whether the compression height (top of piston to the centerline of the wrist pin bore) of 5.0 pistons is the same as that for 4.7 pistons. The block dimensions are the same, the crank stroke is the same, but 4.7 rods are a different part number from 5.0 rods, so I'm guessing they're different lengths to accommodate different compression heights of the pistons.
If the question is can you take a 4.7 block (and girdle) and bore it out to 100 mm and fit everything else from a 5 liter motor, yes, you could do that.
Archive Gatekeeper
The pistons or the block?
Basic Site Sponsor
Basic Site Sponsor
The 4.7 liter block gets a bit "thin" at 100mm bore.
I generally use a 5.0 block when I want to go to a 100mm bore.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
What I want to do is bore the block to 5.0 and use S4 pistons on the 4.7 rods. I have 5.0 rods as well. The other thing I want to do is use the 16V 4.5 heads if bore the block as well. Opinions please.
Cheers
Scott
Cheers
Scott
Cheers
Scott
Basic Site Sponsor
Basic Site Sponsor
Another way to look at it....
If you have a set of 5.0 pistons without a home, what do you have to loose?
About 16 mm thick.
Administrator - "Tyson"
My 79 is at 3,000rpm going down the highway.
Survival at high(er) RPMS is a function of the lower end's strength which we know is rather strong on these cars if tuned correctly. If the thin cylinder walls are going to fail, it's going to be at peak torque which is much lower in the RPM range.
If you don't tune it correctly and detonate the snot out of it, all bets are off no matter what RPM you seek.
Basic Site Sponsor
Basic Site Sponsor
In my opinion, it is tough to make a "universal" statement about wall thickness....it's going to depend on the specific block.
There's quite a bit of "core shift" from block to block and the "85/'86 5.0 engines have thicker cylinder walls, to start with, which makes them more suitable for the offset pistons which are upside down on the 5-8 side of the engine.
I have a spare 5.0 S3 motor which will be for sale soon.
Let me know if you are seriously interested and if it is worthwile with the long shipping distance
Probably the best option is to get a S3 (85-86) shortblock and have the pistons fly cut for valve clearance. You'll get a bump in displacement and a slight bump in compression with Euro heads. You don't have to fly cut the pistons, but compression might be a bit high for street fuel if you don't with the euro heads...american heads are a few CC bigger, so it might work...I want to say Euro S heads are around 50-52cc and USA are more like 57cc
