S2 1984 EU non starter
Today ive just checked all the relays and fuses and all ok, car turns over but i still have no spark have checked at the coils and i have nothing not even 12v at the + terminal both cols are brand new Bosch coils. Any ideas out there
Both coils get power from the ignition switch via the central electrical panel, no fuses or relays involved. If you’re no seeing battery voltage with the ignition in the run position then there’s a cabling issue or ignition switch issue. Google wiring diagram for Porsche 928, there’s free copies available to trace the connections. Best of luck.
Basic Sponsor
CPS or the connectors at the harness.
Ok, I'm going to ask how you 'checked' the relays. Do you have a relay tester? Or did you just swap them around (you can use the horn position as a 'test' - If the horn honks, the relay is good).
Is your alarm disarmed? If it's armed the car will not start.
When did it last run? What did you do to it (if anything) since then?
Are you getting 'tach bounce' when you crank it? The tach should bump up and down a little bit when the motor is cranking.
Are you getting fuel injector pulse? Check with a noid light.
FWIW, I had a 'no start' on my 85 S2 a month ago. No spark, no injector pulse. Changed the EZF & LH relays and away I went.
Tested relays via tester
Alarm disarmed
3 years
yes bounces
Have 12 volts at the ignition switch two black wires no power at the coils or the relay ignition feeds but all the diagrams i have looked dont seem to match my CE board
Alarm disarmed
3 years
yes bounces
The relay diagrams you will find on 928gt.com or most other web searches will be the US model version. The Euro S2 model is completely different. It also has a different fuel injection system, different injectors with different impedence, and twin distributors. Here is a list of the relays for the S2 with part numbers.
VIII - EZF
IX - 928.618.109.00 Kick Down (auto)
928.615.125.01 Bridge (5-speed)
X - 141.951.253.B Horn
XI - 928.615.124.00 ABS
XII - 141.951.253.B Fog Light
XIII - 993.615.101.00 Wiper System
XIV - 141.951.253.B Starter (auto)
928.612.473.00 Bridge (5-speed)
XV - 928.618.113.01 Intensive Washers
XVI - 141.951.253.B LH-Jetronic
XVII - 141.951.253.B Fuel Pump
XVIII - 141.951.253.B Fan
XIX/XX - 928.618.107.02 Headlight
XXI - 141.951.253.B Blower
XXII - 141.951.253.B Defroster
I/II - 928.615.115.00 Rear Defroster
III - 141.951.253.B Window Opener
IV - not used
V - 1H0-953.227 Flasher
VI - 928.615.116.00 Window Opener
VII - 928.618.111.00 Headlight Washer System
IV - not used
VIII - EZF
Unless very new, I'd Replace CPS and pay special attention to connector integrity. Bouncing tach doesn't mean CPS is good, I've seen this more than once. Wave form can be read with scope, but most folks don't have them.
Clean computer and injector grounds:
On euro 84 all engine control grounds are attached to pass side cam/valve cover, two different ground points, quite subject to corrosion due to dissimilar metals. This and intermittently ad CPS caused o start problems for me with 84 euro over the years.
Also check little positive wire at battery. Battery must have full charge.
You can jumper the relevant relays to take them out of the picture. And can bypass alarm with a jumper too, search for these procedures using Google and ref rennlist, more reliable than search function usually.
