89 Oil Pressure Sensor Removal
Hi, all. Is there a trick to removing the oil pressure sensor from the block? I have unplugged the wiring from the unit and have the oil filter removed, but I can't find a way go get a wrench to grip the nut to unscrew the unit. I am replacing the three prong with a two prong as I am replacing the harness.
Thanks for the help!
Jason
Jason
Not sure why you would be puzzled about this as the trick is to get the oil filter out of the way.
You have to counter hold the plug it fits into given that if the plug unscrews you spill the guts of the over pressure protection device left right and centre when the spring grenades.
I cannot remember what I actually used when I did mine but I did not find any particular issues doing it [for a change].
Maybe it's the tools I have. I cant get a grip on the sensor nut due to the larger plug nut right above it. I seem to need a bizarrely thin and short wrench of some kind.
Doubtless one of the chaps will have a solution suggestion. I have a feeling I used the open end of a combination wrench that is not as heavy as other wrenches of the same size.
You really need a service wrench for this. Very short and thin. I bought a whole set at Harbor Freight and they are very handy.
15 Pc Metric Service Wrench Set
https://www.harborfreight.com/15-pie...set-93668.html
the only thing wrong with this picture is a set of $50 wrenches at HF
I've heard folks recommend bicycle wrenches - they are thin allowing two wrenches to be used.
Yes that's the set. No need to spend a ton of money on these unless you like to brag!
