Timing Belt Rollers - Two Questions
I am in process of doing a T Belt R and R on my 86 (early) USA car. Its the 4th time since I've owned the car (bought in 1993) but last time was in 2007 (less then 10 k miles ago) but my memory is not good on question #2 below. Question #1 is general. Two questions / comments
1. I removed the three old rollers and took off the seal from the bearings out of curiosity and noted on large roller that the grease inside was basically like black dust that was clumping. Are these bearings usually completely full with grease under the seal? The other rollers grease was not clumped like the large roller but did not have much grease in them. The photo makes it look like the bearings are galled; they are not. The roller rotated smoothly w/o noise, grinding or movement before I took it apart. The "galling appearance" is actually the black grease that is clumped
2. Is the circa-clip the only thing that keeps the roller from rubbing on the tensioner? I just cannot remember. Yes I do have WSM and even a 9201 to tension the belt - need to look again at WSM / Wayne's write up - just asking
86 928 Roller
Thanks all - I have new rollers BTW
86 928 Roller
Received 1,542 Likes
86 928 Roller
86 928 Roller
Bearings are never completely full of grease. they are typically filled 1/3 to a maximum of 2/3 the volume capacity. Generally speaking the baster the bearing will spin the lower the volume of grease.
