Question regarding block differences 4.7 vs 5.0
Hello again,
I noticed a difference between the 4.7 and 5.0 blocks in the flywheel housing.
My new 5.0L block has a fitting/opening that is not found on my old 4.7L block.
I cannot find this feature described in PET, could I please have some help in identifying this feature found on the 5.0L block?
Also, do I need to cover/close this opening off permanently as I continue my assembly? If so, is there a preferred method?
Thank you. Old 4.7 block shown first, lacking fitting....
And below is the 5.0L block, with the KJET dummied above...
Thanks for you time and help !
Archive Gatekeeper
It's for the crank position sensor from the LH2.2 and LH 2.3 cars, '85 and newer.
Team Owner
Get a quarter and JB weld it onto the opening
Inventor
Unfortunately they are blackish again due to bad mixture at startup of engine .. any idea how to clean them
via plug hole?
I am from As, near Genk, about 100km from Brussels where I work'
Luckily, I was able to locate a NOS block off plate from Scheissco.
Don't ask how much I had to pay for this.
