ABS wire cable bracket support?
cleaning up my ABS wire, I think I may be missing a bracket, or some type of support? this thick (6 ga.?) red wire emanates from the driver side cam belt cover, takes a 90' turn
toward the LH inner fender, and then forward, under the PS reservoir, then travels up and terminates at a junction block.
there is a 8mm (approx.) hole in the cam belt cover that may be for a bracket or tie wrap? anyone know about this or have a photo or part number?
Plastic clip hold the ABS wire to the cam cover.
Archive Gatekeeper
There's a gray omega clip that goes in that hole in the TB cover to hold the ABS wire. Part # 477 971 851.
The ABS power junction block cover has been reproduced by Nate (GT6ixer). You might ping him RE: its availability.
is that the only clip required for the ABS wire? wondering if there is another spot on the inner fender?
also, where else is that gray omega clip used?
Archive Gatekeeper
No other clip for the ABS wire, but the routing behind the PS reservoir bracket is important. Usually the insulation is crispy enough that it shows the memory of where it ran.
Gray omega clip is also used on the front knock sensor at the water crossover, and 2 each are used in the doors for the wiring harness, 1 on the run to the mirror and the other on the anti-theft plate (though that may be green, can't remember)
