Cannot separate inner tie rod from steering shaft
I have the inner tie rod tool, I’ve soaked it in PB blaster and tried air tools and a breaker bar.... won’t budge.... I need help!! The outer tie rod came apart with no issues what so ever...
Havent done a 928 inner tie rod yet, but others have a lock washer with a tab on one of the flats to lock it - this tab will need bending away. What do you call the "" tie rod tool" - in my experience you need to counter hold the rack while you apply a wrench to the flats of the inner ball joint.
Where is the ''steering shaft" relevant to an inner tie rod end?
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
Thanks for the reply, no tab but I'm sure years of corrosion in the threads. Took me all day but when I finally decided " if they break, they break" I locked it in my vice and used a 4 foot cheater bar and was able to break them free! Not fun but now it's time to rebuild it (replace all the seals) and get it re-assembled and back in!
