High Pressure Power Steering Line Length?
Ok, here's a question.......
On the assumption that the rack and pump didn't noticeably change locations over the years, why would there be such a startling difference in length between the 1990 and 1991 model years?
This resulted in a serious WTF moment when I pulled the old one out and compared it to the new one.
We've determined that the longer hose that was in my car is for a '91 and the much shorter new one is apparently for an '87 to '90.....
Thoughts on this one????
And does the "short hose" actually install properly??
The variance is startling....
Basic Sponsor
Longer is better - right?
Basic Sponsor
That is a large difference between 90 & 91. 91 had the 100 bar pump and the so called HP rack. However the mounting points were the same as was the location of the connecting points on the pump.
So WHY the large increase in length and shape?? Run must be different as well - need to look at my GTS.
The shorter hose just supersedes the longer one. I just replaced a long hose with a short hose on my '88. I think its a better design, and the long is NLA, I believe. Getting the banjo bolts aligned is always a pain, but easier if you have someone on top to help move the hose around up there. On the pump side I dropped the pump and started the banjo bolt with the pump down and then set it back in place. If you are by yourself it helps to tape or wire the hose in about the right position up top before trying to get rack side banjo bolt in. I replaced both my '93 and my '88 and the short hoses worked fine, so I would say it fits all S4 and later cars.
Basic Sponsor
Power Steering Hose - Pump to Rack - 85 to 90 928 347 447 05
Power Steering Hose - Pump to Rack - 91 to 95 928 347 447 07
Basic Site Sponsor
Basic Site Sponsor
The '91 to '95 hose clamps to the chassis in a completely different spot.
It's pretty simple, guys:
Install the correct hose for your model year.
We are very proactive about replacing power steering pressure hoses, after getting in two cars that caught on fire, last year. If the hose has not been replaced, we strongly suggest to our clients to do so.
Ok. In reassembly phase now......anyone know off hand if the anti-roll bar clamp bolt torque is supposed to be 33 ft lbs or 62 ft lbs???
Based on the input from this thread, I Fire-sleeved the new hose that will be going into my car tonight.
