Good deal on OEM style intake tubes...
No affiliation. Just passing along. I noticed that my intake tubes are starting to deteriorate and crack. A quick search found these on sale at eEuroparts for $93 each. Not as cheap as the hose replacement kits from 928INTL but they have an OEM style and are MUCH less than originals.
Time will tell if the quality of the plastic will hold up to engine bay temps. I know URO has a poor reputation for quality, but since its just a plastic tube, I don't think they can screw it up too much. https://www.eeuroparts.com/Parts/449...PA92811027204/ https://cimg1.ibsrv.net/gimg/rennlis...93d083e578.jpg |
This does not fit the 85-86.5 US models.
z driver, are you going to order those, or just commenting? If you get them, please report back on this thread once you do. Thanks, Jason
You can get those for $50 each all day long from the usual suspects.
Originally Posted by Randy V
(Post 15767592)
For the 85-86.5 US intake, Roger sells a kit utilizing Mercedes intake hoses and appropriate Silicone connectors.
See my Avatar. |
Originally Posted by Mark Anderson
(Post 15767594)
Those days are long gone
(Post 15767592)
z driver, are you going to order those, or just commenting? If you get them, please report back on this thread once you do. Thanks, Jason |
I stock them for $89 each. I have 12 sets in stock
We also stock the Mercedes based intake tubes for $115 the pair. See below ---- center joining tube is available in Black, blue & red. https://cimg1.ibsrv.net/gimg/rennlis...d7f38b306c.jpg I was knee high to a grasshopper the last time the originals were $50 each 8>) |
I also remember GTS calipers were $331 each back then as well. Then Porsche decided to put a 1 in front of the price :rolleyes:
(Post 15767594)
So if the "good deal on OEM intake tubes" as noted in the title of this thread is $93 each, then is the Roger's price for $89 for OEM intake tubes a GREAT deal?
It just slays me when people think they have found the deal of the century and never check with the suppliers that will day in day out provide the correct parts that fit our cars. Rant over. |
^^^ spot on, sir!
Originally Posted by Jason89s4
(Post 15766929)
The URO tubes arrived on Thursday. These are the tubes I bought from eEuroparts for $93 each. Everyone else I found on line had them for $125 +/-, but based on a reply above, Roger sells these for $89 each which is an excellent price. The finish and thickness of the plastic appears to be as good as OEM. I have no reason to believe they will split or wear out any faster than OEM tubes. What IS different is the flexibility of the accordion section. The OEM tubes have a nice "slinky" feel in their ability to bend and move to line them up at the ends. The URO tubes are not as flexible and have to be "man handled" to get them into place, especially as they are straight when they are new. This also makes it more difficult to work them under the strut bar. They would install easier by pulling the strut bar first, but not required. I also expect that as they heat cycle the will gradually form in the correct shape and future removal and installation should be easier. Also, the air-filter end of the URO tube is slightly longer than stock. I used an exacto knife to trim about half an inch off that end of the URO tube. Below are some photos of stock originals vs the URO. https://cimg3.ibsrv.net/gimg/rennlis...fd0f862238.jpg New URO tube on the left, old OEM tube on right. https://cimg9.ibsrv.net/gimg/rennlis...cd42ac998b.jpg New URO tube installed https://cimg2.ibsrv.net/gimg/rennlis...eaa80bdbfc.jpg Engine bay with original OEM intake tube on left and new URO tube on right, for comparison. |
Edit: delete
