928 Forum 1978-1995
Sponsored by: 928 Specialists
Stock Exhaust ‘85 to ‘83 928?
Old 04-09-2019, 09:47 AM
16vsilverstreak
16vsilverstreak's Avatar
Default Stock Exhaust ‘85 to ‘83 928?
What are the chances of an 85 928 exhaust from the down pipes to the tailpipe bolt onto an 83 928? Both cars are US spec. Thank you.
Old 04-09-2019, 09:18 PM
The Forgotten On
The Forgotten On's Avatar
It will bolt right in and fit. You just need a dual cat to make it work. I'm doing this to my 81 as well.
Old 04-09-2019, 10:30 PM
16vsilverstreak
Fantastic!
Old 04-09-2019, 11:08 PM
skpyle
skpyle's Avatar
Guys...I thought the outlet spacing of the exhaust manifolds for the 32V S3's was significantly different from the prior 16V engines?
I have read where guys have to cut/weld and/or make special spacers to fit S3 manifolds to existing 16V exhaust systems. I would think the reverse is the same...
Old 04-09-2019, 11:18 PM
16vsilverstreak
That does make sense. It all depends which way that extra cam and valves went.
Old 04-10-2019, 12:22 AM
skpyle
skpyle's Avatar
Silverstreak, I don't think that is as much of an issue. On my 32V S3, the cam sprockets are in the same physical location as those of a 16V engine. The extra cams are inboard of the existing cams. To my understanding, the tubular S3 exhaust manifolds are constructed to be a bit wider than the cast exhaust manifolds of the 16V engines.
Understand that I am just reciting what I have seen on my Red Witch and have learned on Rennlist. Do NOT take what I am saying as gospel. Take it as a suggestion to do more research.
Regardless, I don't think it is an insurmountable problem.
Old 04-10-2019, 07:42 AM
WALTSTAR
WALTSTAR's Avatar
I sourced a 85 dual cat exhaust and it bolted right up on my 84 like it was original equipment. I only had to fab a bracket on the mid pipe to hang from a existing body hanger.
Old 04-10-2019, 08:31 AM
16vsilverstreak
I have access to a complete ‘85 exhaust. If the price is right I pull the trigger. Thank you.
Old 04-10-2019, 12:02 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
You said: "from the down pipes", the primary benefit to an 85/86 exhaust on an earlier car is the exhaust manifolds. Are you getting those too?
Old 04-10-2019, 01:37 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
There's a power gain from the S3 car's exhaust on 16v cars if I remember correctly.. You must change the manifolds too though to maximize on it.
Old 04-10-2019, 02:29 PM
16vsilverstreak
I was not planning on getting the manifolds but if they will benefit I will try to get those too if available. Thank you.
Old 04-10-2019, 02:53 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Yes definitely. Do not skip out on those.
Old 04-11-2019, 01:35 AM
Kiln_Red
Kiln_Red's Avatar
+1
I'll go a step further to say that I think it is a complete waste of effort to swap exhaust systems *without* swapping to S3 manifolds.
Old 04-11-2019, 10:02 AM
Wisconsin Joe
Wisconsin Joe's Avatar
Seth - Your Red Witch is an 86.5.
Doesn't it have the S4 exhaust?
Does it have the same manifolds as an 85?
I'm not super 'up to speed' on this, so I may be way off base, but looking in the PET, there seem to be different exhausts for the S2 (84 - 86 Euro - Duals that run together), the 83 - 85 (US - single pipe) and 86.5 (S4 dual exhausts that run separate).
Old 04-11-2019, 09:05 PM
WALTSTAR
WALTSTAR's Avatar
Have you ever done a single pipe to dual pipe swap while retaining the same manifolds? I beg to differ, but it is not a waste of effort. I can feel it in the pedal and the seat. Simply having more cross sectional area as engineered by the factory adds the benefit of more flow. The sound is much more desirable as well.
Quick Reply: Stock Exhaust ‘85 to ‘83 928?
