Alternator voltage drop under load
#61
Basic Site Sponsor
Basic Site Sponsor
^^^^gut feeling (not scientific and no proper deduction) is that alternator is fine. FWIW: here are some readings I just took:
testing at jump post
key off 12.62
key on 12.31 (not started)
on + lights 12.04 (not started)
running 13.84 (no accessories)
+ lights 13.76
+AC #3 13.72
+ AC #4 13.69
+hi beam 13.08 ("full" load)
these numbers are at idle 775. as I rev the car up, charging increases. I held idle up at 3k for a good minute and let go of the linkage and no drastic change in volt meter.
thought I might see a drop.....issue is random...
key off 12.62
+ lights 13.76
+AC #3 13.72
+ AC #4 13.69
Not many 928's are able to do that.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#62
Hey, I agree, Greg. But since they were kind of presented as a series of not started, then started then more loads running, I took it that they do not represent heat soaked conditions.
Very important point.
Thanks, Greg.
Dave
Thanks, Greg.
Dave
#63
I took these readings after driving the car for a few hours: is that considered heat soaked?
#64
Shameful Thread Killer
Ignition module? They have a history. The 15 bus goes through there, also part of the 30 bus I think? Yes, an hour or more driving, the alt is heat soaked.
Moving the goal posts - not fair.
#65
One of the most common heat/electric issues on cars of all makes is called "heat soak." If you drive your car around on a hot day and then park it, the trapped heat under the hood, no moving air, no moving coolant, will actually cause engine temperatures to rise for a while (several minutes) as your engine becomes a heat sink. A common example is drive around, park and come back out ten minutes later and it won't start. But if you wait thirty minutes it will. This is from the starter solenoid becoming "heat soaked" and it won't work.
-Jason
-Jason
However, as the others have said, your voltage readings look very strong.
Generally, it is hard to diagnose "random" issues when the car is parked and the condition is not presenting itself. (I know this doesn't help, but its just the reality of randomness.) Did you mention that your voltage drop symptoms ever happen in your garage, or only when driving?
#66
"the 15 bus goes through there, also part of the 30 bus" not sure I understand relevance or meaning?
and today was the first time in over 2 years, that my car stalled in cold conditions; although, after driving this AM for a few hours, and this afternoon for a few more, car would not stall
while AC, and loads were present??
#67
regarding ignition control module, would it help to clean up those connections and hit them with deoxit or do these modules get finicky?
#68
"they have a history" meaning, they are akin to a wear item and need periodic replacement?
The two primary power buses in the 928 are the 15 and 30 bus. Obviously, the primary power bus has to go to the ign switch so that all of the features that can be run from start up, to running will trigger off the turn of the ign switch. The 30 bus has power any time there is a battery present in the car. The ign switch delivers power to the 15 bus which then distributes power to the various circuits that make the car run. If the key is turned to start, and the starter turns, when you let off the key, it is in the 'on' position, and power goes to all engine running circuits via the 15 bus(and in some cases, direct, and in some cases via a relay or fuse or both). A fault in the ign switch could shut off power to the running circuits of the car.
#69
ok, that's a horse of a different color: not sure I understand how the ignition switch would create the symptom I am having? would it be a good idea to get in there and clean the connection contacts, or is the problem you refer to internal to the switch?
#72
An ignition switch can turn off your ignition. It can be unpredictable. If it stalls or misbehaves, you could try jiggling the ignition switch. Not definitive, obviously, unless it restores function on several occasions. The switch is known to be problematic. It tends to be off or on, not in between.
Good luck,
Dave
Good luck,
Dave
#73
Good luck,
Dave
Good luck,
Dave
but my mind is wide open to other thoughts.....
#74
Yeah, you're probably right. Your problem sounds like a voltage regulator that sometimes works properly, and sometimes does not. The ignition switch was brought up, so I wanted to explain that they often fail, intermittently. It does seem unlikely that this would cause variously low voltage problems. I did have an alternator that seemed to have one bad diode, which when replaced gave me back an additional 1.5 volts. Maybe some such item is starting to die on yours. Mine failed gradually, then constantly, before repair.
Good luck,
Dave
Good luck,
Dave
#75
Tend to agree that my experience with ignition switch issues is a pass or fail proposition. Not a slow voltage "death" like merchauser is experiencing sometimes.
