928 Forum
Sponsored by: 928 Specialists
HELP! A few ?"s ...and did I mess something up?
Old 04-01-2019, 03:09 AM
crushingday
crushingday's Avatar
Default HELP! A few ?"s ...and did I mess something up?
I have a 1978 Porsche 928 that I purchased new in the summer of that same year. I am a real stickler for keeping it ALL original. I have gone so far as to have the factory air in the tires drawn down into a holding tank and later put into my next set of tires. I am so **** about originality that I am still using whatever oil came in the car from the factory, never changed it! 10w30 I think?
Anyway, long story short. I decided to do some cleaning and maintenance to the car and I am afraid I may have caused damage.
I heard that where the air goes into the carburetors can get dirty and that sand blasting the them can do a good job at freshening them up. Not wanting to disassemble anything, (I'm not mechanically inclined at all), I removed the air filter and had a friend rev the engine while I slowly fed fine pool filter sand into the intake. All seemed good for a while as the V8 vacuumed in the cleaning agent. Then without any warning what-so-ever, the engine groaned to a stop and made a large popping or backfire type of sound! What the hell! I tried to restart the engine, but no dice!!
I figured I would let the engine rest for a bit (it was smoking rather substantially at this point) and move on to working on the cosmetics. Anyway, after giving the 'ol girl a good washing with some "Spic n Span" I got one of those right angled spinny drill things and some 220 grit sanding disks and began to gently buff the hood. Man!, Lemme tell 'ya, It wasn't easy cause this drill thingy was jumping and skipping around the hood somethin' awful! At one point it flew out of my hands ricocheted of the windshield and wheeled itself down my gravel driveway only coming to a stop upon reaching the end of the extension cord and unplugging itself. Not to be deterred, I fetched this Godforsaken she-devil of a spinning top, held it real tight and applied pressure to buff the hood. I had this thing in check for bit then suddenly it started turning my white paint to a grayish silver color. Heavens to Betsy, What is going on here!
crushingday is offline
Old 04-01-2019, 04:16 AM
gazfish
Happy April 1st everyone.
gazfish is offline
Old 04-01-2019, 07:40 AM
beran earms
beran earms's Avatar
Original air.....Nice!
beran earms is offline
Old 04-01-2019, 08:22 AM
Christopher Zach
The sand problem is pretty easy to fix: You need to replace the water/ethylene glycol solution in your radiator with a 50/50 mix of chlorinated pool cleaner and water. That should shock your car's engine and get everything right back on track. Be sure to replace your oil with ammonia as well to clean out any residue.
Do not however then fill your automatic transmission case with bleach, mixing the two is a bad idea.
C
Christopher Zach is offline
Old 04-01-2019, 08:42 AM
linderpat
linderpat's Avatar
And here I thought it was the rock star drugs talking! Nice one Ross!
linderpat is offline
Old 04-01-2019, 09:08 AM
Hymodyne
User
Hymodyne's Avatar
Ross- I started reading, my jaw dropped, and then...Oh, April 1st...
Nice.
James
BTW, when is the band back in OC?
Hymodyne is offline
Old 04-01-2019, 10:05 AM
drooman
drooman's Avatar
drooman is offline
Old 04-01-2019, 12:26 PM
NelaK
Originally Posted by drooman View Post
For a 40+ year old car with a questionable service history and undesirable color combination? I'll give you $1000 and you'll pay for shipping.
NelaK is offline
Old 04-01-2019, 02:40 PM
Ghosteh
Ghosteh's Avatar
Don't worry if you lose some of that factory air. I was lucky enough to score some from a dealer years ago. Although it's no longer in the original bulk container, I can assure you that this is the right stuff for both U.S. and RoW cars, and had the correct date code for your '78. I believe you could also use this with '79-82 cars also with only slight modifications. It won't be cheap, but where else are you going to find original Stuttgart air from 1978?
Willing to trade for other rare NOS parts. What do you have?
Ghosteh is offline
Old 04-01-2019, 02:49 PM
crushingday
Stan says I need to power wash the undercarriage with a garden hose and the fill the crank case with DeOxit 100 and drive for a few hundred miles. Then I am gonna get an alignment at Jiffy Lube.
Old 04-09-2019, 04:53 AM
crushingday
Nice.
James
Hey James, We are back at Fagers Island on May 10th. Lemme know if you can join us
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
