Air cleaner rubber mounts
is there a trick or easy way to remove a split air cleaner rubber mount?
and what is the proper orientation? long thread down, into the bracket, or long thread up thru the air cleaner?
Aren't those welded into the bracket? IIRC, you should remove the bracket and drill a hole. I would mount the short side through the drilled hole.
Vise grips on what remains and pliers to hold the bracket in place to prevent it twisting.
I have had success with a small chisel or sharp punch aimed in the unscrew direction, and a few taps with a hammer. For the sheet metal air cleaner brackets, that may only work while off of the car.
