928 Forum 1978-1995
Sponsored by: 928 Specialists
smells of fuel around car
Old 03-16-2019, 11:31 AM
boca928s
boca928s's Avatar
Default smells of fuel around car
So my car is new to me its a 1985 auto... it smells like gas in the garage..but I see nothing on the floor sometimes a little motor oil, see nothing wet on the engine except... I don't know the proper names for these parts, area's but on the I guess intake manifold area of the engine where the oil fill cap is and where the passenger side radiator hose connects to the motor there is a cavity area that gets what looks like motor oil to accumulate there.. I tried taking a photo, but its very hard to get a clear view... ... I had a small puddle of what looks like dirty oil, I checked the dip stick for my oil and the engine oil is super clean.... when I tried to smell the rag when I cleaned it up it didn't have a real gas like smell to it.. so I think its just oil, from where its coming from I don't know... hopefully its just old oil residue.. I plan on having the car looked at for other things and now that, and hope to get the engine all cleaned up after all mechanical work performed..but do you guys know of the issue and what can be the cause? I have not put oil in the fill, so I know its not from adding oil...
Old 03-16-2019, 12:16 PM
Red Flash
Red Flash's Avatar
Do you smell the gas after you have run the car? Or, do you smell it when the car has been turned off even after msny days?
Old 03-16-2019, 12:17 PM
voskian
voskian's Avatar
First, check your fuel lines in the engine compartment.
Second, I had this happen to me, there was a leak from the fuel pump which stayed under the cover and didnt drip on the floor but did evaporate and smell when behind the car.
cover over the fuel filter and fuel pump in rear
Fuel pump and fuel filter under cover
Third, check the evaporator canister under the passenger side of the front wheel well. The plastic three way tube breaks and gas fumes can be smelt at the front.
plastic three way broke
fumes leak out inside passenger wheel well
fixed!
Old 03-16-2019, 12:27 PM
boca928s
boca928s's Avatar
thanks I will look into that tonight
Old 03-16-2019, 12:28 PM
boca928s
boca928s's Avatar
It seems to smell in the garage even if I don't start or drive the car for days
Old 03-16-2019, 12:42 PM
Wisconsin Joe
Wisconsin Joe's Avatar
Can you smell it more strongly in a particular area?
The idea that it smells even when you don't drive the car suggests to me that it's the fuel line connection at the pump or filter. 2 10mm nuts hold the cover on. You can reach them without lifting the car (at least I can).
Pop the cover off and see if there's any 'wet' on the lines. First 2 pics in Voskian's post.
I had it happen too. The first time, simply tightening the connection worked...
For a while.
Replacing the crush washers is suggested and is a much better choice for a long term fix.
Old 03-16-2019, 12:48 PM
Geza
Geza's Avatar
Did you recently fill the tank? If so, good chance it is the fuel level sending unit gasket - simple, $5 fix.
Old 03-16-2019, 01:03 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
also if you filled the tank then the transfer hose could also be leaking, this hose goes through the chassis,
and attaches to the body then to the filler neck.
The return line to the sender. could be leaking.
the transfer line will have fuel spilling down the outside of the tank, look at the tank from under the car, look for wet signs.
the return line will have it fill up the well around the sender connection,
open the cover on the hatch floor to do a sniff test.
The 3 way junction is usually announced when the car is shut off and then the fuel fumes will percolate,
sniff in back of the RF tire , the fumes will come down the wheel well liner.
Old 03-16-2019, 02:01 PM
mike77
mike77's Avatar
Mine failed at the pump and as mentioned the cover hides it. I took the cover off could see anything. Started the car then saw it dripping out. I did the crush washers which lasted a while. I'm just waiting for parts to refresh the whole area as it started leaking again before I parked it up for the winter.
Old 03-16-2019, 02:07 PM
boca928s
boca928s's Avatar
thanks everyone I will let you know if I find anything
Old 03-16-2019, 02:28 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,452 Likes on 1,459 Posts
Smell the right front wheel well above the tire.
Old 03-16-2019, 03:08 PM
SeanR
SeanR's Avatar
Pull your hatch carpet and on the right side you will have a fiber square covering a black round cover. Pop those off and see if you have fuel pooling on top of the tank.
Old 03-16-2019, 03:12 PM
Randy V
Randy V's Avatar
On older models it is often the vent hose has cracked. May not be your issue.
If your Y connector is broken I have an unused one you can have for 10 bucks. I think they are around $20 new.
Old 03-16-2019, 04:38 PM
boca928s
boca928s's Avatar
how do I get to view the y connector? is it under the hood? under the car? It does seem to have the strongest smell around the front passenger fender wheel area...
Old 03-16-2019, 04:47 PM
Wisconsin Joe
It's inside the passenger side wheel well.
Behind the plastic liner.
Quick Reply: smells of fuel around car
