16v rear cam tower seal - 4 holes 3 bolts? - Rennlist - Porsche Discussion Forums
Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Reload this Page >
928 Forum
Sponsored by: 928 Specialists
Old 03-15-2019, 01:41 AM
rjtw
User
Default 16v rear cam tower seal - 4 holes 3 bolts?
I took off both rear cam tower cover plates on my 83 today and reinstalled with Rogerís cool silicone gaskets.
Question: There are 4 holes in the cover plate and 4 holes in the gasket and cam tower. 3 are threaded and take bolts. The 4th is not threaded and appears to extend right inside the cam tower and remains totally empty. These holes open up to air!! Am I missing something why doesnít this leak oil like crazy? Is there supposed to be a plug or anything?
rjtw is online now
Old 03-15-2019, 05:38 AM
gazfish
That's normal, the distributed pressure from the 3 bolts is enough to keep it sealed.
gazfish is offline
Old 03-15-2019, 11:12 AM
Wisconsin Joe
Super User
Wisconsin Joe's Avatar
Nope, won't leak.
There's 4 holes on both the gasket and plate because both sides use the same parts, but the holes in the cam tower are mirror images.
Make sure you follow the torque spec. It's pretty low.
Wisconsin Joe is online now
Old 03-15-2019, 12:55 PM
rjtw
User
Yes very low! I used blue loctite as well. So any idea where that fourth/unthreaded hole leads? When used on the front of the engine that is an oil passage. I inserted a dowel at least two inches into the cam tower from the fourth hole and it just seemed to connect to the inside of the cam tower. But maybe itís an unused oil passage that doesnít communicate with anything. I will assume so!
rjtw is online now
Old 03-15-2019, 10:56 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Since the cam carriers are not rights and lefts, but only one part number and interchangeable from side to side, it is the same oil passage that is on the front.
greg brown
714 879 9072
[email protected]
There's a huge difference between great products and good marketing.
I'm all about the great products.
GregBBRD is offline
Old 03-15-2019, 11:15 PM
Speedtoys
Speedtoys's Avatar
Originally Posted by Wisconsin Joe View Post
Nope, won't leak.
More so with silicone, not sure that's a better solution when the OEM gasket is $1.
Speedtoys is offline
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
